Brake line Loops near prop valve, what for?
My rear line has like 5 loops in it, both my front have only 1 loop, gussing it was just done to take up slack or is there a real purpose??? Ill do it if need be, just don't have a fancy bender for that. |
Re: Brake line Loops near prop valve, what for?
Not sure what those are for, been wondering myself for when I redo the brakes on my 63. They do make a fancy bender for that. It doesn't look like a traditional tube bender tho, they look more like pliers. I've heard they work pretty good.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
I have always thought the curl was to reduce the shock at the fitting on the brake lines(so they can flex and not leak) cheers, Pat
Posted via Mobile Device |
#4 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
![]() Join Date: Nov 2004
Really good explanation, pretty much what everyone says:
http://auto.howstuffworks.com/auto-p...ends-loops.htm
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
