03-14-2012, 04:50 PM | #1 |
broken back
Hey guys my truck's cab is sagging pretty bad. its a c20 and if i can remeber correctly they dont make the mounts for my truck. i know i can remove them and send them out to get replaced but I need the truck running. would the c10 cab mount work, if so send link?? i tried searching but my search thing wasnt working. thanks in advance!
Brandon |
03-14-2012, 05:01 PM | #2 |
...just another truck junkie..
Re: broken back
Yes, the C10 cab mounts work fine. You get the rear mounts and put them on the frame in the same place as your originals. You will need to also get the C10 cab mount bushings and hardware. Not much to it, it is a pretty straightforward switch.
Mike "Bear" Shea |
03-14-2012, 08:51 PM | #3 |
Re: broken back
where can i get the whole set up?
03-14-2012, 10:25 PM | #4 |
Re: broken back
The truck shop has it all but the bolts are too big in diameter you will have to get smaller diameter bolts, I know this because that is what I had top do on my 65 3/4 ton.
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
03-14-2012, 11:08 PM | #5 |
Re: broken back
I just posted on my '64 build thread tonight a super cheap way to solve this. It cost me a total of $58 (Energy Suspension kit, steel, new bolts).
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
