Oil cooler lines leaking
They go from the back of the block to the radaitor on my 6.2. They're leaking where the rubber crimps onto the metal. Just wondering if there is a cheap fix for this?
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
Re: Oil cooler lines leaking
New hose
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Having trouble acquiring them.
your local hydrolic shop could make you new hoses. i know carquest around here will make hydrolic hoses. just take them the hose and they can make a good copy of it
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin 79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s 81 mercedes 300d 25 MPG 77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded" 73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091 '77 chevy trucks. built to stay tough. life is short build a hot rod ![]() |
Moderator
![]() Join Date: Oct 2008
Dorman makes a good replacement for the 6.5 I bet they make em for the 6.2
Thanks, I'll check it out!
![]() Join Date: Apr 2009
Chevy is still having issues with this on their Gas burners and Diesel trucks , Just replaced a set on a 2005 G Van , same problem leaking at the crimp area.
Desert |
Cut off the crimp, replace the hose, and use hose clamps instead of the factory crimp.
Those connections have always been problematic... Posted via Mobile Device
I was worried a hose clamp wouldn't hold up.
I've used clamps to repair a hole in the aluminum line, held fine.
I've also used regular clamps on air lines with 100+ psi. You could double clamp it with the clamps on opposite of each other. Heavy duty clamps are also available http://www.idealclamps.com/catalog/index.php?ID=3 The replacement cooler lines will leak again, it's just a matter of when. Seems to be an inherent design flaw or designed to fail for future parts sales... Posted via Mobile Device
![]() ![]() Last edited by joe231; 03-14-2012 at 11:33 PM. |
I would use an 'A/C' clamp. Its the one that has a finger on it. I used one in a pinch and it worked good. I would get one sooner than later. When it comes off, its bye bye engine.
I would second the dorman hoeses, they seem to work good. |
The auto parts store I go to was able to order them....they're a locally owned shop that's comparable to NAPA.
I used to work in reaction injection molding and dealt with a lot of hydraulic hoses....they all fail at the crimp over time.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
