Old 03-14-2012, 08:54 PM   #1
mfencl
1968 chevy c10 non powere steering column
My steering column broke park is straight up towards the roof of the cab (automatic) I canbarely go into drive its where 2nd should be my friend is a mechanic and said there's a spring or smething that's holds the column in place its in side the column its self idk if anyones knows what I'm talkin about or how t fix it but does anyone knw where I can get a new column? Thanks matt
mfencl is offline   Reply With Quote
Old 03-14-2012, 09:29 PM   #2
chiefcfd
chiefcfd's Avatar
Re: 1968 chevy c10 non powere steering column
It sounds like the linkage between the frame and transmission has come loose. Look under the truck and see if everything is in line. The column uses a tube that shifts the linkage. If there is that much travel it has to be something else. Hope this helps.
chiefcfd is offline   Reply With Quote
Old 03-15-2012, 08:21 PM   #3
mfencl
That's what I thought so I did that but the column its self is moving like rotating to the left towards park like if I were to slam it in park the column moves to the left and if I were to put it in 2nd it moves it t the right but steering wheel itself doesn't mve it'll stay ? Any thoughts n that?
Old 03-15-2012, 08:55 PM   #4
sjarrett71
sjarrett71's Avatar
Maybe one of the two clamps came loose? You can look for a replacement column on the parts section of the website. There are usually a few there at any given time.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 03-15-2012, 09:13 PM   #5
mfencl
Alright thanks sir yeah my friend said its inside the column but I was just seein if there's anyway t fix it
Old 03-15-2012, 09:44 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Read this thread and see if it helps any...
http://67-72chevytrucks.com/vboard/s...d.php?t=188438
LockDoc
Leon
Old 03-15-2012, 11:11 PM   #7
The retaining ring under the hood at the firewall "and" the u-clamp under the dash must be loose,allowing the entire housing to rotate. There is just not that much travel within the column itself to allow what you describe. As far as not going into all the gears,once the column is in the correct position,there is a linkage rod the connects the column shifting mechanism to the transmission linkage. There is a barrel bolt off the column's shift arm that clamps that rod in and is your linkage adjustment. Generally,you will either get no "park" or no "low" depending on which way it's out of adjustment.
See the shifting arm and barrel bolt in the picture?
