Old 05-04-2003, 08:14 PM   #1
short step
power steering box?
what power steering box can i use in a 71 c 10. there arnt many 71s in the salvage yards around here
short step is offline   Reply With Quote
Old 05-05-2003, 12:20 AM   #2
lost wages
lost wages's Avatar
any box will work, in the 80s the hoses went metric, i have a 76 1/2 ton truck power steering box on my 68.
lost wages is offline   Reply With Quote
Old 05-05-2003, 12:27 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yup...69 up to 82 I think. It was early 80s when they went to the metric crap.
I think you need the pitman arm off the newer boxes...but I may be mistaken.
Old 05-05-2003, 12:45 AM   #4
crazy longhorn
Fabricate till you "puke"
The metric boxes will work also ,if you change the hoses. I have an 84 burb box on my 69. Best to get the pitman with the box if you get into the 80s metric pcs. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
