Old 03-14-2012, 10:15 PM   #1
Budman56
Budman56's Avatar
Shifting linkage
Hey all I need some ideals about how to connect my late model tilt steering column to my turbo 350. Can any one least me down the right path.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 03-15-2012, 12:24 AM   #2
RAYDAY
RAYDAY's Avatar
Re: Shifting linkage
depends on the year of the column. if it was a factory rod style like up to mid 90's you can salvage some oem parts and get it to work or lokar,ididit,ect all make linkage kits. If its 96 on up cable style idk why u use it? but, u can use the factory cable have to make some brackets on trans.
96 s10 static drop smooth and blue
99 silverado nothing stock layed out on 24s
65 c10 bagged patina driver
http://www.myrideisme.com/Garage/az480
half-assed build thread
http://67-72chevytrucks.com/vboard/s...=1#post5206828
RAYDAY is offline   Reply With Quote
Old 03-15-2012, 04:08 PM   #3
brawley
Easy Does It
brawley's Avatar
I had the same issue and ordered one from www.clasicperform.com they have a shifter linkage thats adjustable ,worked out great
brawley is offline   Reply With Quote
Old 03-25-2012, 08:42 PM   #4
low79fx
This is what I did ,used cable out of a 98 s10 Blazer made my own brackets.
http://67-72chevytrucks.com/vboard/s...d.php?t=398171
low79fx is offline   Reply With Quote
Old 03-25-2012, 10:56 PM   #5
Budman56
Budman56's Avatar
could you post some photos of your shifter linkage, I bought the cpp kit but I cant get it to work, maybe if I seen what you did I can get mine to work.
MY 65 C20 BUILD
Old 03-26-2012, 12:15 AM   #6
losthope
losthope's Avatar
budman check this link out, it says to place the arm that mounts to the trans at the 8' o'clock position for park :
http://www.classicperform.com/tech_a...geStoryweb.pdf
In the picture you posted of how you set yours up in your other thread you have it in about the 11' o'clock position so thats why its not shifting....
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
