Has anyone built a tailgate extender?
Has anyone fabricated a tailgate extender or found one to fit a squarebody? Having a shortbed is awesome, but sometimes being short has its badside
![]() It's almost motocross season here. Now that I have two bikes, when I transport them to the track I can't close the tailgate. It's annoying because then I have to bungee tie and strap down my equipment inside the bed. I was thinking about making something out of wood or even PVC piping. I guess I would have to add some type of brackets to stay stationary in the bed for the extender to slide in and out of. Any ideas?
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch |
![]() Join Date: Oct 2011
Re: Has anyone built a tailgate extender?
i remember those days, with two bikes and sb always had to bungee the heck out of everything....
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
At the body shop.
I tied the gate to the foot peg. Gate was mostly up every thing stayed put.
" That didnt make it any newer " " Dont antique the equipment " |
Ever look at those "bed extender" that Nissan Titans come with as an option?
Posted via Mobile Device ![]()
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Yes, those are what I originally looked at but they don't make any specific to a 73-87. They are pretty pricey too. If they made one specific I would consider but I'm not spending that kind of money to have to modify it anyway.
Well some square tubing and a welder and you shouldn't have an issue. Make it to were it rotates on two pivot points on the square posts so you can rotate it from in the bed over and out to the tail gate. That way it don't have to be round tube or fancy
![]() Join Date: Jul 2010
I don't think pvc would be to lite of thing to use & wood would work fine..but if you going to use it to help secure tha bike..i'd use 1x1 square tube..if you can weld..you can bolt tha corners to gather with L brackets...maybe 2 rows..with some flat stock to act as diagonal's..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
5 minutes to late with tha square stock post..lol
![]() Posted via Mobile Device
Collector of Projects
Take a tape measure to walmart and start measuring truck beds to see if one has the same width as your truck.. then see if you can find one on CL... Stay away from PVC. Too flimsy and UV from the sun will ruin it...
The 1x1 square tube does sound like a better material to use...
