Old 03-15-2012, 01:04 PM   #1
Spille85
Need help with door rubber on 1967 C20
Hi everyone,
Well I've finally decided to start working on my late fathers C20 and after cleaning the cab up I noticed that the door rubber seals need to be replaced, but I noticed the metal door trim is rusted out. I'm not sure the name of this metal strip, but its what the rubber seal attaches to. Anyone know the name and where I can buy a replacement?
Spille85 is offline   Reply With Quote
Old 03-15-2012, 05:35 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Need help with door rubber on 1967 C20
Are you referring the lip all the way around the door opening or the metal door sill at the bottom.
Can you post a pic?
68gmsee is offline   Reply With Quote
Old 03-16-2012, 10:59 AM   #3
Spille85
Yes, exactly what I'm referring to. I will post a pic later today for clarification. Thank you so much for your reply. Marty
Old 03-16-2012, 05:22 PM   #4
aventur1
aventur1's Avatar
Mine had a spot on drivers door side. I cut a piece of aluminum angle and glued it in place.
1968 4x4 Frame, with a 67 Cab and Bed
A Shorter Step
1999 Dodge 2500 Cummins Diesel
aventur1 is offline   Reply With Quote
