Old 05-04-2003, 08:52 PM   #1
ratrod67
ratrod67's Avatar
driveshaft question
I want to convert my 69 SWB 2 piece driveshaft into a 1 piece. How do I measure to get the right length? Do I slip the yoke in 1/2 way so I still have some travel when the truck drives? Thanks for any help.
ratrod67 is offline   Reply With Quote
Old 05-04-2003, 09:19 PM   #2
Class of 69
Class of 69's Avatar
Yes,then measure from the center of the u-joint to the center line of the u-joint cap at the rear yoke.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 05-04-2003, 11:11 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you have a short shaft TH350 hooked up to a small block then you'll need a shaft that is 4 foot 10 inches.
That's what mine is. 69 SWB GMC 350/th350.
Old 05-05-2003, 12:33 AM   #4
crazy longhorn
Fabricate till you "puke"
Slide the slip yolk in the trans till it bottoms.....then pull it back 3/4 to 1", & measure C to C on the caps for the lenght on the shaft. You want as much spline buried as you can get, but just enough room for a little travel & not bottom on the trans shaft. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
