Old 03-15-2012, 06:27 PM   #1
69gmc292
6 cylinder header question
Is there special spacers for 6 cylinder headers? I was given a header but it did not come with any hardware. I plan on using the stock intake and the #1 and #6 cylinder mounting blots are longer then the rest and I don't know what to use.
thanks
69gmc292 is offline   Reply With Quote
Old 03-15-2012, 07:20 PM   #2
longbed67
longbed67's Avatar
Re: 6 cylinder header question
If no one on here knows tom will.
http://www.stoveboltengineco.com/
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 03-16-2012, 08:21 AM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
You may have to modify some of the spacers to fit your application. One thing you want to do is replace is the mounting pins in front of Cylinder #1 and behind Cylinder #6 with either cap screws [bolts] or threaded studs. They will back out with WD-40 and a Vice Grips. They are threaded 3/8-16 UNC. Headers are less likely to leak that way. You may want to use all new bolts, or 3/8-16--3/8-24 long studs with securing nuts. The stock fasteners may not fit with the headers. What headers are you using?
