Turn Signal Switch Problem
I need to purchase a new turn signal switch. When looking at LMC, I found three different switches for the varying years (#31).
![]() 73-76 77-83 84-87 Here is my dilemma: my truck is a 73, but my steering column is from a 78. Which do I purchase? I would figure 78 but idk what is the difference? Wiring? Diameter? I called LMC and all the rep could tell me was the wires on the 73-76 is 20" long. Can you guys help?
1973 C10 350 700R4 |
Re: Turn Signal Switch Problem
I'd get the 78, and if need be switch terminals on plug if needed.
if its 78 column go with that. i would first go to the junk yard and look at the up close and see what the differents is
thanks for input, guys
