Front sway bar mounts
is there any place that sells bolt-on front sway bar brackets with holes to line up an original sway bar? Im putting 71 spindles, disc brakes on my 70 and if my a-arms dont have the sway bar holes im gonna use the a-arms too. I cant get a compressor or a cutting torch to the donor truck to cut the rivets and steal the mounts tho.
Yeah, Early Classic sells them, 20 bucks plus shipping.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
cool. i shoulda thunk they did.... they do so much suspension stuff. ty man
go bucks!
you could just grind off the heads of the factory rivets,too. save the dough,dude........my.02
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
i cant get any kind of power tools out to the donor truck it's in a self-service yard.
Chisel and a two or three pound sledge will work. Few good blows will take the heads off those rivets, no problem.
you must be a big ol' boy. I wiegh one 65 and i can barely knock off the head of a 3/8 bolt thats had the head drilled through with 1 hit. I'm thinkin about taking a battery drill out there and drilling it out. I have an inverter but you cant take your vehicle out there either. It takes 5 minutes per rivet with an air chisel and my tank is only good for a couple minutes of solid stream. That wont work either. I think the elec drill thing will though. i have 2 drills times 2 batteries each. ty for the help fellas. i gotta show you my hammers tommorow... heh you bring up a good topic.
I don't think a battery drill would make it, maybe with a hell of a bit set. I think if you get a chisel and a big ass hammer and convince your self that rivet has been talkin trash about your momma, you'll get through it. I've done it a few times.
When I got mine the guys at the yard were nice enuf to torch them out for me. Still a self-service yard but they occasionally help out. Have you asked?
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
