Registered Cruiser
Electronic Throttle Body... change?
Need some help guys....
Have a 5.3 out of an 03 Tahoe. Getting ready to start the rebuild to put in my 77. My question is, it has an electronic throttle body. I would like to change to cable throttle, is this a simple change?? Don't have the pedal assembly for it, what are my options? Thanks, Justin
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
Always a work in progress
Re: Electronic Throttle Body... change?
Yes it is a simple swap as long as you have the right computer and harness. You can use your stock intake you will just have to find a way to put some inserts or studs in the empty holes. You will need a Red/Blue connector computer and matching harness.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
Registered Cruiser
Ok, I don't have the harness or computer... I'll start looking around yards and CL/Ebay see what I can find, thanks for the help!
Also look on ls1tech.com I found a harness and computer for $150 shipped.
Also read here bc I explained how I added studs on my intake for the throttle cable bracket.
http://67-72chevytrucks.com/vboard/s...d.php?t=514236
Registered Cruiser
I've been pluggin around there lately, just trying to get as many opinions as I can
![]() When I'm looking for a DBC throttle body, is there a kit I need for the cable and brackets, or can I use a factory style from the older pickups?
A guy with a truck
99-02 truck throttle body will work. You can also grab the inserts from the yard- just break em off with channel locks. Heat them and push into your intake...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
I bought a lokar throttle cable and a stock bracket and any 3 bolt throttle body will work.
Registered Cruiser
Great, thanks guys!!!
You'll want the wiring harness with red/green connectors, i know for sure those are for the cable setups. Couldn't tell ya if there were ever any of the blue/green connector combos setup for cable. I believe LT1swap has a list of ECMs determined whether they are flexible for either setup. If not, i have a list made up that i can either post on here or PM to you.
It should be red/blue
Registered Cruiser
Thanks guys!!!
Now, what if I decide to go to an LS1 intake? Same cable throttle body? Fuel rails...?
#13 |
TB should be fine, get the rails and crossover tube from the ls1 to simplify things.
#14 |
Registered Cruiser
Thanks man!
And one last question for now ;P.... My 5.3 has cathedral ports, what do I need to look for when searching for a used LS1 Intake? I see a bunch around EBAY/CL but not sure how they match up, the port on the intakes I've seen are square...?
