Old 03-16-2012, 12:50 AM   #1
59weasel
donor truck for the '66...what do you think?
have the option to grab an '87 chevy 2wd 1/2 ton for $250.00... think this is a good donor for the daughters '66 3/4 ton swap? all there, body is bad and the V6 is toast. but all suspension is intact and 3:42 ratio in the rear would probably be fine for her and the straight 6 in the '66. i know the rear is a little wider and will need mounts but no biggie. what do you guys think?
'59 SWB (the money pit)
Camaro clip/5.3 LM7/700r4/10bolt rear/bagged/and some mild mods here and there.
'93 Jeep Cherokee with some stuff. (the toy)
'06 Silverado 2500HD (daily driver)
'12 Equinox (wifes ride)
'66 Chevy LWB (daughters ride)
59weasel is offline   Reply With Quote
Old 03-16-2012, 12:59 AM   #2
MisterC
MisterC's Avatar
Re: donor truck for the '66...what do you think?
Great find for that price. I say go for it!
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 03-16-2012, 01:22 AM   #3
Rich 5150 69
Rich 5150 69's Avatar
I don`t believe the front crossmember (suspension )comes out, I think that stopped in `86, you`ll have to look at it to be sure.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 03-16-2012, 02:19 AM   #4
Rooster's 67
Rooster's 67's Avatar
Yup perfect candidate for suspension swap. any 73-87 will work great.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 03-16-2012, 12:44 PM   #5
59weasel
thanks guys, Rich 5150 69...i was under the impression that they did. i could see the two side bolts that go through the top of the craddle and through the frame. guess i'll have to go double check today. I kinda thought i could use the power stering and the brake system also, to try and keep it all from one truck / year.
Old 03-16-2012, 01:11 PM   #6
MisterC
MisterC's Avatar
I'm sure CaptainFab will chime in to confirm, but it should be a straight swap.
Old 03-16-2012, 01:15 PM   #7
chevyrestoguy
chevyrestoguy's Avatar
It's the perfect candidate. For $250, that's a great deal. When you're done, you'll be able to get that much (or more) for the scrap value of what's left. It's a win/win!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 03-17-2012, 12:12 AM   #8
59weasel
totally what i'm thinking! i think i have the wife on the same page now.
Old 03-17-2012, 01:07 AM   #9
Captainfab
60-66 Nut
Yes that is a good donor for your '66 C20. However, you will have to change the entire front suspension, crossmember and all. You can't just change the control arms on the '63-'66 C20 and C30's.
Old 03-17-2012, 02:43 AM   #10
Rich 5150 69
Ok so I lied, not sure what year was the cutoff.
Old 03-17-2012, 11:21 AM   #11
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Can't you just swap the upper a-arms and spindles?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-18-2012, 01:01 AM   #12
Captainfab
60-66 Nut
Not on the '63-'66 C20's. The C20's use a larger lower ball joint, so the C10 balljoints will not fit. The '63-'66 lower control arm shafts are flat, so there is no saddle to accomodate the C10, or '67+ C20 lower control arm shafts.
