Old 03-16-2012, 01:33 AM   #1
Fldawg
Fldawg's Avatar
brake pedal clevis adjustment
Hey guys need a little help, just finshed putting my disc brakes on the back of my truck, i also put a new booster master cyl. and 4 wheel disc prop valve on. my question is , is there a rule of thunb on the clevis adjustment on the pedal or somrthing more to it. i cut the new rod on the booster to my old booster and adjusted pedal to the top, but i dont' have much pedal travel and i'm having a hard time getting my brakes to bleed out. any help would be appreciated.
Fldawg is offline   Reply With Quote
Old 03-16-2012, 10:11 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: brake pedal clevis adjustment
Originally Posted by Fldawg View Post
.......... i cut the new rod on the booster to my old booster and adjusted pedal to the top, but i dont' have much pedal travel and i'm having a hard time getting my brakes to bleed out. any help would be appreciated.
This part confused me. Which rod did you cut and why?
And on the part of brakes not bleeding out. Do you mean you don't get any fluid to the brakes?
I'm not familiar with the disc/disc system but maybe someone else has installed one and can help.
68gmsee is offline   Reply With Quote
Old 03-16-2012, 02:58 PM   #3
Fldawg
Fldawg's Avatar
Disrecard guys had a major brain fart, got it figured out
Old 03-16-2012, 04:23 PM   #4
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
I wondered what that smell was in Tallahassee...LOLOLOL
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 03-16-2012, 06:06 PM   #5
Fldawg
Fldawg's Avatar
What a funny man, i figured you come over and help me, good lord knows i need it after this rear wheel disc conversion.
