03-16-2012, 10:14 AM | #1 |
90-91 suburban cluster
I'm using the cluster for a LS swap in a 77 K5 if anyone has a link to a wiring diagram for the cluter I could sure use the help
Thanks |
03-17-2012, 01:26 PM | #2 |
Junior Member
Re: 90-91 suburban cluster
04-02-2012, 10:05 PM | #3 |
you can take the pins out of the original connector. just trace the wires out to where they go, write em down. then it's a simple job to put the wires where you need them to go.
EDIT: that link looks like it just saved you a little time. i did mine in about 30 mins tracing the wires out and rearranging them. |
04-03-2012, 01:46 PM | #4 | |
Ephesians 2:8
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
