Old 03-16-2012, 10:56 AM   #1
AngryPirate
AngryPirate's Avatar
1961 ashtray
I'm embarrassed to ask this question but I would rather not force it. Is there a trick to getting this thing into the dash hole?
Perhaps my ashtray has a part that is bent an I don't know it. The thing will not go in.
I was missing mine and I got a used one, cleaned it up and painted it. I'm trying to slide it back in and it just won't go.
Man, I feel dumb. :-/
If no tricks, does anyone have a few different profiles of their ashtray so I can compare?
Thanks,
Scott
AngryPirate is offline   Reply With Quote
Old 03-16-2012, 11:29 AM   #2
62 Barnfind
62 Barnfind's Avatar
Re: 1961 ashtray
My factory radio was keeping mine from going in. Once I removed it it worked fine.
62 Barnfind is offline   Reply With Quote
Old 03-16-2012, 11:30 AM   #3
61K10
61K10's Avatar
Re: 1961 ashtray
you have to push down on the tab that you put the cig out on. bottom in 1st then push down on tab. if it won't go something is bent?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-16-2012, 11:33 AM   #4
AngryPirate
Re: 1961 ashtray
I wish that was my problem. No radio there.
It's the type that is at the top left of the center dash.
Like this one (not mine).
Old 03-16-2012, 11:35 AM   #5
AngryPirate
Re: 1961 ashtray
Yeah. I figured that was the way but I feel like I'm forcing it way too hard.
The bottom rail might be bent one way or the other.
Thanks.
Old 03-16-2012, 12:14 PM   #6
jbgroby
jbgroby's Avatar
Re: 1961 ashtray
I too had problems with mine. Take a careful look at the bottom of the tray and see IF the pivot hindge point is bent up. You can get it in but because of the pressure the pivot puts against the dash, it does not quite sit correctly, I'll fiddle with mine later to try to see what is the issue.
jbgroby is offline   Reply With Quote
Old 03-16-2012, 12:19 PM   #7
AngryPirate
Re: 1961 ashtray
Nice to know I'm not the only one. So the pivot hinge should be at what angle relative to the bottom of the ashtray? a 90 degree? a 45? Currently it's at probably a 20 or 30 degree angle (the best way I can really describe it relative to the ashtray).
Thanks.
Old 03-16-2012, 01:18 PM   #8
jbgroby
jbgroby's Avatar
Re: 1961 ashtray
From my POV its a mix of bending the lip on the dash part and fiddling with the part of the ashtray. also a smear of lithium helps with the squeek.
Old 03-16-2012, 01:35 PM   #9
l79m20
Re: 1961 ashtray
we are nothing without the squeek!!! sigh......................
l79m20 is offline   Reply With Quote
Old 03-16-2012, 02:49 PM   #10
AngryPirate
Re: 1961 ashtray
okay...got it...fiddling may be required.
add grease as per taste.
ashtray
