Old 03-16-2012, 06:59 PM   #1
sighlurr
______________
sighlurr's Avatar
1971-1972 Coil Spring 5 Lug 12 Bolt
I'm looking for a 12 bolt from a 1971 or 1972 1/2 ton coil spring truck with 5 lug axles.
Let me know what you have.
925 979.8161 - call or text
sighlurr is offline   Reply With Quote
Old 03-16-2012, 07:18 PM   #2
WETOWM
Re: 1971-1972 Coil Spring 5 Lug 12 Bolt
I have 1 i just pulled from a 72 i am parting not sure of gear ratio looks all original and not rusted or pitted
WETOWM is offline   Reply With Quote
Old 03-16-2012, 08:19 PM   #3
sighlurr
______________
sighlurr's Avatar
I'm assuming shipping from MO to CA would be more expensive than the rearend...
Old 03-16-2012, 09:50 PM   #4
WETOWM
I thing it would i guess you can check some truck line prices ?
Old 03-16-2012, 09:52 PM   #5
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
I can have it shipped very cheap!!! Just need weight and dimensions...
Note: Rear ends weight substantially more than what most people assume... 300-400 lbs depending on make...
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline   Reply With Quote
Old 03-16-2012, 09:57 PM   #6
HeavyMetalChevy
Just a Member
from st. Louis to Walnut Creek, CA @ 400lbs $183.42... I think 12 bolts are more like 300 lbs though...
TH400(3rd)
Old 03-16-2012, 10:00 PM   #7
HeavyMetalChevy
Just a Member
I just got palletized weight of 230 lbs... anyone help??? Got it from google...If that is the case it will be SUPER CHEAP to ship!
TH400(3rd)
Old 03-16-2012, 10:16 PM   #8
HotRod C/10
HotRod C/10's Avatar
thats what I came up with.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 03-16-2012, 10:17 PM   #9
teeitup
Just like to part out trucks!!
teeitup's Avatar
I've got like 8 of them out there
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 03-16-2012, 10:36 PM   #10
sighlurr
______________
sighlurr's Avatar
Can you send me some pictures? Also, can you pull the cover for the gears?
Old 03-16-2012, 10:43 PM   #11
HeavyMetalChevy
Just a Member
$159.62 @ 230 lbs
TH400(3rd)
Old 03-16-2012, 10:45 PM   #12
sighlurr
______________
sighlurr's Avatar
Originally Posted by HeavyMetalChevy View Post
$159.62 @ 230 lbs
Good to know, thanks for your help. We may be able to shave some more weight too, because I won't need to drum brake setup on either side.
Stay tuned..
Old 03-16-2012, 10:46 PM   #13
HotRod C/10
its getting more affordable by the minute..........
LS SWAPPED
-1976 SILVERADO
Old 03-16-2012, 10:49 PM   #14
HeavyMetalChevy
Just a Member
Hah Hah... Yep... It's what I do... That was still from St. Louis too. Randy is quite a few inches closer.. lol
TH400(3rd)
Old 03-16-2012, 10:54 PM   #15
HotRod C/10
im 1200 miles closer, :-)
LS SWAPPED
-1976 SILVERADO
Old 03-16-2012, 11:10 PM   #16
teeitup
teeitup's Avatar
Duane, would it fit on a pallet without hanging over? THANKS for all your help!!!!!!!! Randy
1980 chevy swb 4x4
Old 03-16-2012, 11:25 PM   #17
HeavyMetalChevy
Just a Member
I just had a cab shipped on one pallet...found it does not matter as long as it is palletized... sweet
TH400(3rd)
Old 03-16-2012, 11:28 PM   #18
teeitup
teeitup's Avatar
WOW good to know, THANKS man!!!!!!!
1980 chevy swb 4x4
Old 03-16-2012, 11:39 PM   #19
HeavyMetalChevy
Just a Member
yes... I am working on getting those doors, that clip, a cab in Nevada(got that sold) and just purchased a 67 cab and front clip in Cali... lol what am I doing???
TH400(3rd)
Old 03-17-2012, 12:05 AM   #20
HotRod C/10
i looked a t a rust free cab today if interested has doors gauge cluster and the seat. 700.00
LS SWAPPED
-1976 SILVERADO
Old 03-17-2012, 12:56 AM   #21
HeavyMetalChevy
Just a Member
then the ship cost would kill it.. .I am in Indiana
TH400(3rd)
Old 03-23-2012, 11:42 PM   #22
sighlurr
______________
sighlurr's Avatar
Got a rearend locally. Thanks though for all of your help.
Old 03-24-2012, 12:26 AM   #23
shawno72
C/10 junkie
shawno72's Avatar
Think you can find another? We're pretty close?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 03-24-2012, 01:06 AM   #24
sighlurr
______________
sighlurr's Avatar
I've got a factory posi 6 lug rearend out of a '70 leaf spring truck..
Old 03-24-2012, 08:48 AM   #25
shawno72
C/10 junkie
shawno72's Avatar
What are looking to get for it?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
