Old 03-16-2012, 09:19 PM   #1
crr26@cox.net
crr26@cox.net's Avatar
seat mounting
i have a 72 blazer and in my build i decided to rhino line my entire floor so i welded up all the holes then rhino lined it. i was planning on installing a 3/8 bolt with large washer on bottom and a finger style washer to hold the bolt in place. my problem now is i forgot about the rocker boxes. i cant pass the bolts from underneath because they are in the way. any suggestions on how to mount the seats. the two holes drilled in the pic were where i was going to relocate the seat brackets to allow the seat to go back as far as possible. please help!Name:  blazer floor.jpg
crr26@cox.net is offline   Reply With Quote
Old 03-16-2012, 10:15 PM   #2
NorCalTank
Re: seat mounting
Why can't you pull the rocker box end cap off?
NorCalTank is offline   Reply With Quote
Old 03-16-2012, 10:59 PM   #3
29od1
Re: seat mounting
Brilliant!!!
29od1 is offline   Reply With Quote
