Old 05-04-2003, 11:26 PM   #1
WB72
Before and After
WB72's Avatar
Question 1/2 ton and 3/4 ton interchangability
Can you change the front suspension from a 3/4 ton to a 1/2 ton a frames, spindles, ect. or are the frames different?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 05-04-2003, 11:55 PM   #2
crazy longhorn
Fabricate till you "puke"
yes you can change to 1/2 ton pcs......swap the lower a arms, balljoints, & tierod assys & the spindles will bolt on. My 69 has been done that way(still has the stock crossmember & 3/4 top a arms). Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-05-2003, 07:31 AM   #3
Woody
Crazy Longhorn,
What did you do for the top ball joints? Did you use the 3/4 ton ball joints or swap in 1/2 ton ball joints? What about the idler arm and Pitman arm?
Thanks!
Woody is offline   Reply With Quote
Old 05-05-2003, 08:04 AM   #4
crazy longhorn
The top balljoints were 1/2 ton pcs,& they bolt to the 3/4 ton a arms. The lower arms had to be changed, due to the difference in hole sizing for the balljoints. my 69 had been swapped to 3/4 ton discs previously(71 parts). When I swapped to 1/2 ton pcs, I changed the tierod sleeves,& outer tierods(same centerlink, & inner tierod ends, idler & pitman). if you can peel all the parts off 1 truck, you will be ahead of the game tho (no guesswork). Good luck,crazyL
Old 05-05-2003, 11:02 AM   #5
WB72
Before and After
WB72's Avatar
What about the rear, do the coils interchange as well?
66,000 miles.
Alberta, CANADA
Old 05-05-2003, 11:24 AM   #6
crazy longhorn
my longhorn is leaf, so Im not 100 % positive......but i think you can swap the 1/2 ton rear diff,coils, track bar & bracket to get to the 5 lug deal.........crazyL
