Old 03-17-2012, 12:22 AM   #1
BrookelynnGreen
BrookelynnGreen's Avatar
Engine Question
1986 Chevy C10
350 Engine
4 barrel Carb
Ok, so I have had this truck about 5 months. Its my daily driver. I drive to and from work, to and from school and every tuesday and wenesday I drive approx 40 miles @70mph to Augusta kansas and back. I changed my oil about 3 months ago and my oil was pretty low. My coolant looked a bit low also. Is it normal that its consuming that much oil? I do drive it pretty hard. There is no external coolant leaks or external oil leaks. Could it be due to my driving hard? And I just checked my oil stick, the oil coming off the stick seemed "a bit thin". I use 10W30. My truck drives great!! Never overheats. Never stalls, and it drives great going out of town. I'm wondering if I should be worried??? Please help.
-Samuel
"Knowledge Is Power"
BrookelynnGreen is offline   Reply With Quote
Old 03-17-2012, 08:37 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Engine Question
10W30 oil isnt as thick as some oils... when its warmed up oil thins..Im sure that youre burning some oil thats prolly where the loss is coming from.. check the oil every day and also in three months id be do for an oil change prolly
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-17-2012, 01:57 PM   #3
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Re: Engine Question
How much oil did you add?
A quart of oil use in 3 months of consistant driving is not a big deal.....
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
Old 03-17-2012, 02:04 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Engine Question
Your engine may be a little worn and maybe eats a little oil. As well as a small oil leak can make it low as well. Make sure to change your oil every thre months or 3000 miles.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-17-2012, 04:30 PM   #5
beamn7
Re: Engine Question
GM's guideline for TODAY's engines in cars and light duy trucks under 8600gvw is 1qt every 2000 miles. For vehicles over 8600gvw it is 1qt for every 100 gallons of fuel consumed which if you are averaging 8mpg equates to 1qt in 800mi....
Keep in mind, that is for TODAY's engines which have much tighter tolerances, etc and are not 25yrs old so loosen up those numbers a bit to compensate for the age, etc.
Some oil consumption on an older engine is expected, as Insidious noted, could be slightly worn out, maybe a leaky valve seal(s), etc.....
Unless is puffin' blue smoke, I would worry about it too much, just keep an eye on the oil level and keep it changed regularly.
beamn7 is offline   Reply With Quote
Old 03-17-2012, 09:46 PM   #6
butch86
butch86's Avatar
Re: Engine Question
i have a 350 in my 70 chevelle and i use about 1/2 quart every tank of fuel. it been that way since the day its been built. its really a lose motor. if your only losing a quart or so during 3000 miles your doing good with a pre 90s gm motor.
butch86 is offline   Reply With Quote
