Just a Member
Holley 1850-S 600 cfm
This is a totally operational and mechanically sound Holley 1850-S 600 cfm carb. I ran this on both my 327's and 350's. Performs well. DOES NOT NEED REBUILT. Square bore, vacuum secondaries, with manual choke. Universal throttle linkage.
4160 model 4-barrel carburetors. These carburetors are equipped with Holley's all-new Tru-Set needle and seats, which have eliminated the need for external adjustments. This change allows for easier "bolt-on-and-go" performance. The floats have been factory-set for optimum fuel levels at 3 to 6 psi of fuel pressure and should never need adjustment. If you're running over 6 psi of fuel, a fuel regulator is required. $150 shipped CONUS OBO these run $260 new. I can guarantee working condition
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog Last edited by HeavyMetalChevy; 03-18-2012 at 09:35 PM. |
Just a Member
Re: Holley 1850-S 600 cfm
ttt
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
Just a Member
ttt
Just a Member
ttt
whats the best you would do ship'd to 28036....thanks billy
Just a Member
That is pretty firm... This thing is in perfect working order and a great carb... esp with a performer intake combo... AWESOME mid range rpms... I had it on a stock 67 truck motor with not so great horsepower and it would freaking get it!!!!
i seen you put obo on it...thanks anyway,billy...
Just a Member
whats the offer???
$100 ship'd...thanks billy
Just a Member
I will split that almost in the middle at $130. That's about 15% off the original price and over half off new price. As mentioned before.. This carb is in new condition and perfect working order...
Just a Member
ttt
Just a Member
ttt
#13 |
Just a Member
cmon' man
