03-17-2012, 01:25 PM | #1 |
rear bag bracket question
I have a 67 C10 with trailing arms. I plan to put in a c-notch (not the tall one, the bolt/weld in one that just goes up into the frame) then bag it. My question is: what are the best brackets/location to use? I am not trying to lay frame, just wanna get as low as possible and have a decent ride. Any advice on location and bracket set up will be helpfull!
Roll Chevy!
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
03-17-2012, 02:38 PM | #2 |
Happy to be here
Re: rear bag bracket question
Check our Vendor Marketplace. Several of our Forum Sponsors offer a small bolt in notch that will fit your needs.
03-17-2012, 07:17 PM | #3 |
Looking for bag mounting bracket suggestions... I have seen em bolted in the same posit as da springs and off to the side with brackets. Not sure which is better or what exact brackets I need to make it happen.
Sorry, Da vender marketplace isn't very user friendly IMO Posted via Mobile Device Posted via Mobile Device
03-17-2012, 07:18 PM | #4 |
...and I have the notches, looking for bag mount brackets for the rear.
03-17-2012, 07:37 PM | #5 |
67-72 parts collector,…
Just mount the bag between the frame and the trailing arm.
No brackets required.
03-18-2012, 03:20 AM | #6 |
If you just replace the coil springs with bags it will get it pretty low with that small notch.
03-18-2012, 03:36 AM | #7 |
on my previous setup I had my bags mounted where the coil springs used to be.I used slam specialties bags(built in bump stop).with the notch you're going to use and a slam specialties bag,with the bags deflated the axle will be about 1/8-1/4 inch from the notch.
ken |
03-19-2012, 11:51 PM | #8 |
Sounds good, thanks for the info.
