05-05-2003, 01:27 AM | #1 |
update pics
Got the fuel tank mounted and plumbed. All new wiring and ran all new steel fuel line. Got some of the frame painted. Getting really close!!!!!
Pic 1
68 short fleet with 71 front clip 2wd jaguar blue 99 chevy ext cab shrtbed z71 loaded 99 chevy swb fleetside(daily driver) Sparks, Nevada |
05-05-2003, 01:28 AM | #2 |
Pic2
05-05-2003, 01:28 AM | #3 |
Pic3
05-05-2003, 01:29 AM | #4 |
Pic4
05-05-2003, 01:30 AM | #5 |
Pic5
05-05-2003, 01:35 AM | #6 |
Of course you know someone was going to ask, What kind of tank is that and how easy was the install, any snags?
Looks real nice and clean back there, good attention to detail.
Jeremy '71 C-10 '72 GMC K2500 '72 Nova (Dad's) '70 Chevelle SS '55 Sedan Delivery Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall |
05-05-2003, 01:40 AM | #7 |
former desert rat
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
My question exactly. Looks like the same one in Slammed67's truck. Might it be a Summit tank? Got the part number?
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const. |
05-05-2003, 01:44 AM | #8 |
The tank is a summit 16 gallon fuel cell with sender. Part #sum290100. It was actually really easy to install. I just had to notch the front crossmember a little bit due to the crossmember being slanted. Thanks for the compliment. Next weekend the axle and the Trailing arms are going to get painted.
05-05-2003, 01:51 AM | #9 |
It is the same as slammed67's. I got the Idea from him. And if you see this I would like to say thanks again for the info.
05-05-2003, 10:00 AM | #10 |
Post Whore
Nice addition. You gonna shave the cab gas filler?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
05-05-2003, 07:10 PM | #11 |
Ya. this weekend I'll fill in the old gas hole.
05-05-2003, 07:36 PM | #12 |
Very cool. I am getting ready to do the exact same thing this weekend. looks very nice. on a side note what size cowl is that on the hood and where did you get it. keep up the good work cant wait to see it finished.
05-05-2003, 07:48 PM | #13 |
Better late than never
I don't know why, but I didn't give any thought tp moving my tank from the cab until today. That looks like a good setup. How are you handling the filler tube? Inside the fender? Also in one of your pics it appears that the tank rides pretty low below the frame rails. I have straight exhaust pipes, so I guess I would have to go out the sides like you did.
Thanks for the info.
1970 C/10 SWB Stepside |
05-05-2003, 08:08 PM | #14 |
chevykid1969> The cowl is a standard 2 or 3" cowl. I got it from a local dealer here in town that has now gone out of business.
Keh> The fuel fill on a fuel cell is in the center of the tank. I think you can see it in the pics. Alls I am going to do is install a door right above it in the bed. The tank only hangs below the fram about 4". Witch isn't bad at all. A freind installed the blazer tank and it hangs lower than that.
05-05-2003, 09:32 PM | #15 |
yeller
Good lookin work Frost..I like it!
Here is my 73...alot like yours. What is the box type thing on the rear of the chassis? -Jeff |
05-05-2003, 10:45 PM | #16 |
The box on the back is a junction box for all of my wiring. I call it a berg box. It has 8 terminal posts on the inside to connect all of your wires. Thanks for all of the compliments.
