05-05-2003, 01:29 AM | #1 |
Under construction!
Sound like a good plan?
Well, I tend to skip around when working on my truck. I thought it would be a good idea to make a plan and stick with it. My problem is debating when I should have the interior re-painted...!?! Anyway, tell me what you think.
Truck Build-up Guide The following is a simple and basic overview of my truck build-up sequence. Rear Suspension---Being that I already have ART’s parallel 4-link and FBI step notch, I’m going to finish the back. Once those components are installed and I can manually inflate the air springs---I’ll purchase the front Cool-Ride kit. Drivetrain---I’ll remove the engine, transmission, and everything in the engine bay. Bodywork---I’ll remove the inner wheel-houses, fenders, and entire radiator support. Front Suspension---After the suspension has been removed, I’ll paint the frame and cross-member. Once the PST bushings are installed, I’ll paint the control arms and other components. Next, I’ll install the suspension and replace miscellaneous parts as needed (Wheel bearings, etc.) Bodywork 2---I want to shave/smooth the firewall and paint it the color of my choice. Cameron Park Auto Body or Lonnie and myself may complete this step. Drivetrain 2---Henry and I will install a factory replacement GM 350 crate motor. Prior to installation, I’ll paint the engine and transmission. This step will only involve installing the actual engine, not the accessories. Interior---I’ll remove the entire interior. Bodywork 3---I’ll have bodywork completed in the following stages: 1. Cab 2. Front end 3. Bed At this time, I am not sure what modifications will be done. Drivetrain 3---After the front end has been bolted-up, I’ll install all engine accessories. During this step, I’ll also organize and detail the engine bay. Interior---??? Wheels and Tires---I plan on running a 20/22” wheel combination with low-profile tires. Braking System---I plan on purchasing a rear disc brake conversion kit, front upgrade kit, and new proportioning valve from SBC. That’s it for now and I’ll see how my plan works out.
2001 Silverado bagged on 22's. *Sold* |
05-05-2003, 07:26 AM | #2 | |
Signals in the bumper.
Re: Sound like a good plan?
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
05-05-2003, 01:00 PM | #3 | |
Under construction!
Re: Re: Sound like a good plan?
Nope, not yet. I am keeping the factory dual tanks.
05-05-2003, 04:05 PM | #4 |
Have you talked to ART about it cause I had to remove my saddle tank due to using a parallel four-link.
05-05-2003, 04:36 PM | #5 | |
Under construction!
Nope. 5-8Chevy has the same kit and factory dual tanks.
05-05-2003, 04:44 PM | #6 |
You guys must be using the shorter four-link...20". My bars are 30" for a little bit better ride.
Sounds like you have it covered though.
05-07-2003, 01:28 AM | #7 |
And what kind of budget are you planning on spending !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
05-07-2003, 02:08 PM | #8 | |
Under construction!
I'm going to estimate around 25-30K from this point. It's a long-term project though.
