Engine cut-off switch?
Has anyone installed a engine cut off switch on their trucks to keep them from getting stolen? I've seen a couple of people with fuel cut-off switches but wouldn't it be easier to have an ignition cut-off switch for older cars like ours?
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
Re: Engine cut-off switch?
I wired one before, mounted the switch under the seat. Just wired it to the HEI dist connector, would crank but never start unless switch was on.
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
Also does anyone know how to wire one into your neutral safety switch?
#4 | |
Happy to be here
![]() Join Date: Mar 2000
Use a 12v relay to break the circuit and hide the trigger switch.
![]() Join Date: Jul 2010
I had tha idea of maybe useing a switch that mounted under tha carpet..that when you step on it & turn tha key..then it starts...
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
What kind of relay should I use and how would I wire it? I would guess the output would go to the NSS and an input would be the toggle (which would be connected to the original NSS wire) but what would another input be?
Happy to be here
The ground side of the N/S switch can be broken through the relay circuit of a Bosch style relay as pictured below. One wire goes to ground, and a trigger wire goes to +12v. This opens and closes the relay using what ever method you prefer.
From what I've been reading the "to pump" would the be to the N/S switch right? So you would have ground, constant power, trigger, and then the output to the N/S? Sorry just not very knowledgeable with this stuff. I'm thinking about running a wire under the carpet to the cargo light switch and using it as a toggle because I don't have a cargo light.
Also, crawled under the dash today and the NSS has 2 purple wires (one solid and another with a white stripe) and two green wires. Which wire should I run through the switch?
Interested in this also. Subscribed.
Jeremy I have done so much, for so long, with so little, I can do anything with nothing! 1984 GMC Sierra Classic-1/2 ton-SWB (R.I.P.) 1986 GMC Suburban 3/4 ton 4x4 2014 GMC Sierra LTZ Z-71 Crew SWB |
I use:
Battery cut off switch to the starter. Kill switch to the spark box, theres a wire that when grounded the box wont turn on. and well the alarm system. |
You can also splice an on off switch on the inductive pick ups to the ign module so there will be no signal to the module an no spark from the coil. Mines glued to the back of the glove box.
Three inch wake the dead exhaust and Manual steering and a non choke competition carb also deter theft And a better deterent... Winchester Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#13 |
I've noticed having a clutch is a huge anti theft device.
Wiring a switch that would kill power to the dizzy and hiding it would be a good idea tho
![]() 305 ci | TH350 | NP208 | 60k miles |
#14 |
![]() Join Date: Jun 2011
A hidden dizzy switch and well hidden lithium powered GPS tracking device is what I have planned.
#15 |
Another Day, Another Dollar
I have a hidden night swit directly in-line with the hot side of the starter
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
#16 |
78K & 79C Jimmys
alarm and kill the coil
crank,crank,crank,crank,crank, it should still be there in the morning,cause now it's flooded lol dosn't stop the push away and try again tho crank,crank,crank,crank,crank, most joyride kids would give up and run at this point I'd run swiftly carry a big stick ,thud depending on how far you are from my trucks,you won't hear exhaust unless they start mine are quiet just cranking ,till they start I have a funny choke too but if they are warmed up,maybe they watched me come home,waiting.then it's just a turn key.and it's gone I'd rather have to change the oil......
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#17 |
At the body shop.
Straight column is much harder than a tilt column to steal. The start rod runs down the top of the column. Most thieves rip the side of the column up...
" That didnt make it any newer " " Dont antique the equipment " |
#18 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Old thread, but exactly what I'm planning.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#19 | |
