![]() Join Date: Oct 2009
1969 Speed Warning Speedometer Question
I bought this instrument cluster at an auction and do not know much about the speed warning option. The speed warning needle turns fine and gets tight down by 20 mph so I think it is all working correctly but the speedometer needle is not. First of all it is sitting in the middle. It is not frozen. The part where the cable attaches still spins both ways but when it is spun forward the needle seems to move as fast as the back is being spun and then went it gets clear around to pegged the needle stops and the when I stop spinning it the needle comes back around and stops randomly in the middle. If it is spun backwards the needle does go down to zero and stays there until it is spun forward again. I know the speedometer are specific for these clusters and if it is junk that that makes a big difference in this clusters value. I really do not want to disassemble this cluster but I have someone interested in it and would like to tell them what this might be so they know what they are buying. So it is hard to explain what it does but hopfully you can understand what I am saying. Thanks for your help.
**If this is in the wrong area please move it.**
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
Re: 1969 Speed Warning Speedometer Question
Surely someone knows what I am talking about and can shed some light on it for me. Thanks again for any information.
![]() Join Date: Apr 2010
Todd, it sounds like the problem is in the speedo mechanism. The needle can be removed and all the gears can be removed and put onto another speedometer that is working properly. There is a spring that is on the s/w needle that will trigger the buzzer but it should not have anything to do with it stopping in the middle like that needle is doing. If the guy that is interested in it doesn't buy it, let me know I would be interested in it.
#4 | |
I have this cluster listed in the "WIW" area but if I put it up for sale I will put it in the "Parts For Sale" area and let you know. Thanks for the information.
Yes, the speedometer parts are the same
Thank You, that helps.
