Oil Filter Adapter
I've read several threads but nothing really helped much. I have a 283 that I need the spin on oil filter adapter(s). I already got the Mr. Gasket round piece that fits into the recess, is there something else I'm missing like the by pass valve adapter?
anyone have a picture? Thanks.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
Re: Oil Filter Adapter
I also have a 283 and have an adapter.the parts as far as know of are
The gasket that fits between the block and bypass The bypass and the spin on adapter, also the two bolts that are used to secure it. The only thing I'm not sure of is what's used to seal the adapter to the block. I think it's a round rubber seal like what's used on the original canister oil filter housing. I got my engine back in parts so I never saw it put together. Posted via Mobile Device |
This is the one that I used on my big block, but it will also fit an early small block. I think you can order a similar one from Summit. Hope this helps.
![]() Join Date: Sep 2005
thats what i used on my 305 i didn't use a gasket and have had no issuses
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
I have this one laying around. I have used similar on my 283's over the years.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Ok,
going to bring back this old thread. the 283 in my 66 has this adapter (was leaking) and I also snapped a pic of what the block looks like. There is a hole in the block picture about 1 o clock. And the plastic black piece is pretty hard, should it be rubber and more plyable? I was using a K&N oil filter which seems to seal well against the face of the adapter. Am I missing some other piece? If I were to replace this assembly, what should I use? thanks!
i don't see the gasket that seals the adapter to the block
the gasket would be the same gasket that seals the old canister to the ring in the block your adapter does not have a bypass, i wouldn't worry about it unless you go 8000 miles between oil changes
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Ok, let me run through a few things just to make sure I understand the information I'm getting and reading.
I can use this piece This is the proper stock bypass that would work with it which I can either use, or not use... ![]() Other side of bypass valve. ![]() and this will allow me to use standard chevy filters (which don't have bypass valves in them)... OR I can use this part that and go with a ford type filter. ![]() If all this is correct, then great, however, what is this piece and is it an option? Better / worse? It appears that using this would require that the oil filter seal up against the oil filter boss on the actual block itself, not like the previously listed adapters. I'm sure I'm overthinking this but I want to do this once, do it right and have it not leak!
But your block looks different than a modern SBC. I'm not sure the filter would seal with a later adapter
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#10 | |
![]() Join Date: Aug 2010
You will need the conversion adapter. The most common one uses a Ford filter.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
Right as rain you guys!
I just tried to 'match up' the new oil filter (K&N hp3002) and it WILL NOT seal against the block so that later model bypass valve adapter in my last pic will not work.
LDO, This is the adapter I have for my motor. It is a small journal 327. I have had the motor for about 20 years. As OGRE said, if you dont run the oil for a long time you should be fine. Im no filter expert, but the filter has an internal bypass. The adapter i have is one you show in one of the pics posted.
This is the filter i use. Hope that helps, good luck. |
#13 |
Thanks Bubba, yes that helps. I was getting hung up with so many different options. The kit you are running seems like a reliable and inexpensive solution.
#14 |
late answer on my part but that style of adapter absolutely has to have the stock bypass valve used with it or you end up cracking the adapter when you tighten the bolts down along with distorting the adapter and causing oil leaks. I've been there and done just that not knowing that I needed to retain the stock bypass valve.
#15 |
yes,
I have read that as well. The part that I removed was installed without the bypass (second) part and looks a little bent and had been leaking. I ordered the perma-cool 1134 adapter from summit this morning along with a backup set of gaskets. http://www.summitracing.com/parts/PRM-1134 I am hoping for a leak-free future!
#16 |
That should work ok. I'd use one of their suggested filters though or a the Wix or Napa filter that crosses from the HP-4.
I see that Perma Cool sells a replacement gasket and O-ring for that setup if you need them.
#17 |
Yes, I ordered an extra set of gaskets as well.
#18 | |
#19 |
Thanks. Geeze, I hope I don't go thru that! I haven't started up the motor yet since I've got other things going on but I sure hope I've got this thing centered and the gaskets installed correctly.
If this fails, I'm going with the stock bypass and mr gasket type adapter. You are correct, I'm ready to move on to other things besides oil leaks!
#20 |
Got the girl running today and zero leaks!!!
Took a while to get her back on the road bit i did alot of needed maintenance on her. I replaced... the fuel pump, summit All fuel lines, fittings and connections with russel pro flow stuff. Valve cover gaskets, edelbrock extra thick Oilpan, stock from summit Oilpan gaskets, felpro one piece Dip stick, lokar Inner dip stick tube, GM Cap & rotor, Accel Plugs, Accel shorties Plug wires, MSD Oil filter adapter, perma cool Oil, Castrol 20w50 Oil filter, K&N And cleaned & painted everything needing cleaning and painting. Took her out on a test ride, no leaks, no fires and nothing fell off so things are looking pretty good for now... Thanks to all who helped and provided opinions and advice. This place is like a room full of older, more experienced brothers that i can come to for help. Thanks. Posted via Mobile Device
#21 |
Congrats on getting back on the road. Checked out the 66, the torque thrust and the flat black look great. Hoping to have my 54 in flat black someday.
Good luck with truck Shawn |
#22 |
Glad to hear you got that leak fixed. I was able to get a few more things done on my truck as well. Pedals,Clutch linkage,shift linkage, and turn signal/ steering wheel have all been put back on. I almost want to test drive it like it is ( cab only,no doors,fenders,or hood) lol
