CLR'd my tailgate this morning... happy boy
A few weeks ago I tried CLR on the driverside of my truck, I didn't get the results I had hoped for...... the paint is just too thin.
This morning I tried it on the tailgate and it helped alot. I used steel wool and a green scuff pad.
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
Re: CLR'd my tailgate this morning... happy boy
Wow, that made a huge difference!
Posted via Mobile Device |
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
That worked great!! I have read a few threads, and looked at a bunch of pictures that show the same results. I can't wait until my truck is at that stage, so I can try it!
LOL it kinda looks like you wiped your trucks a$$
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201 no garage, no shop, limited storage space and tools....no problem. |
LOL, Gives a whole new meaning to "skid marks"....
![]() Join Date: Nov 2011
Hey Sig...are you using water and CLR or just scrubbing on the CLR?
This is actually Lime away which is the basically the exact same thing. Lime calcium and rust remover. I used a small spray bottle, diluted it half and half with water, spray it on let it soak a few minutes, use steel wool for the light areas ( with just brown looking stain ) and a green scotch brite for areas that has more rust showing. spray the steel wool or scotch brite along with the body of the truck and start rubbing. rinse with a hose and re apply as needed
I did several spots on the passenger side later today and it worked well also.
When the truck sat for 35 years the pass side was again some trees that i guess helped it from the wind and elements, the driver was exposed to the open yard and the paint is worn thinner on this side
![]() Join Date: Oct 2009
that stuff's a miracle worker. Looks great!
Who Me?
Just to add something to this. Has anyone used Sno-bol toilet cleaner? It works great on rust too.. I have used it to move rust on concrete and does a great job.
DISCLAIMER: I have not tried this on a truck. Use with caution!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
