Old 03-18-2012, 05:37 PM   #1
willywoo28
Carb Spacer Question --Gaskets?
Hello Chevy land!
I have had a warm starting issue for the past 6 months, and finally broke down after a lot of troubleshooting and purchased a 4 hole x 1" spacer from Edelbrock (phenolic). It did not come with any gaskets.
1) Is that how they normally come?
2) Do I need gaskets to sandwich the spacer?
3) If I do need gaskets which ones work best?
I am curious because I was wondering if the Phenolic material will conform to both the intake and bottom of the carb?
Thanks for any ideas/help you can give.
willywoo28 is offline   Reply With Quote
Old 03-18-2012, 08:02 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Carb Spacer Question --Gaskets?
You need gaskets for sure
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-18-2012, 08:16 PM   #3
Pop's C-10
Pop's C-10's Avatar
Go to tha parts store look in tha section that has tha dress up items..you will see gaskets you need..they even have spacers..you need one on both sides..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
