Old 03-18-2012, 08:46 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Do I have to change out the oil pan?
I have a 72 burb with a 04 Tahoe 5.3. The burb is bagged with 22's in the front, but may go to 20's.
Putting in the tranny this weekend, just didn't want to do it until the pan was changed if it needed to.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 03-18-2012, 08:55 PM   #2
OneOffStroker
Re: Do I have to change out the oil pan?
You shouldn't have to change out the pan unless you have some crazy setup planned. The stock truck pans fit in these older trucks, but it may hang a little low if you're planing on dragging frame. If that's the case, you could raise the motor and trans with creative mods to the motor mounts or find a different pan.
OneOffStroker is offline   Reply With Quote
Old 03-18-2012, 11:50 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
what setup? I think you're OK if you're using a PB dropmember...otherwise you might need to swap to a shorter pan.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-19-2012, 09:54 AM   #4
Daaaanz67
Check out hartrob burb build post 475
Daaaanz67 is offline   Reply With Quote
Old 03-19-2012, 01:56 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
The truck pan WILL hang down. I personally wouldnt want that to be the lowest point on a bagged vehicle...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-20-2012, 04:50 PM   #6
5150
C10 Club Tennessee
5150's Avatar
Just a stock frame, it is a 73-87 crossmember. I won't be dragging the frame or anything crazy like that.
Bryan
www.gmtruckshow.com
Old 03-20-2012, 06:12 PM   #7
mooseknuckles
mooseknuckles's Avatar
the stock truck pan will hang below the stock crossmember 1"-1 1/2"
mooseknuckles is offline   Reply With Quote
Old 03-21-2012, 03:56 PM   #8
68Stepbed
68Stepbed's Avatar
Bryan. I'm actually going to change my pan because it hangs below the crossmember. You know how low my truck is static dropped, and I'm not comfortable with it. I'm buying an F-body pan from a guy locally. I know of a guy on LS1Tech.com that has a CTS-V pan if you wanted to go that route.
Let me know if you want me to put you in contact with him.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-21-2012, 05:41 PM   #9
5150
C10 Club Tennessee
5150's Avatar
What's he want for it?
Bryan
www.gmtruckshow.com
Old 03-21-2012, 09:31 PM   #10
68Stepbed
68Stepbed's Avatar
$150 but without the pickup tube. It does come with a gasket, though. I think the pickup tube from GM is only about $20.
Matt
Old 03-21-2012, 09:50 PM   #11
5150
C10 Club Tennessee
5150's Avatar
Matt, can it be changed easy with the motor in or does it need to be out. We were planning on dropping in the tranny this weekend at my cookout.
Bryan
www.gmtruckshow.com
Old 03-22-2012, 05:08 AM   #12
68Stepbed
68Stepbed's Avatar
I'm not really sure, Bryan. If anything, you would only need to lift the engine slightly instead of removing it completely.
Matt
Old 03-22-2012, 10:17 AM   #13
68GMCCustom
likely have to change the pickup tube also?
Kurt -
Old 03-22-2012, 11:24 AM   #14
Custom 68
Custom 68's Avatar
yes and I think the windage tray is also different. Not a big deal.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-29-2012, 09:01 PM   #15
kvn1011
Kvn1011
kvn1011's Avatar
You can trim the windage tray yourself, if i get time ill dig up the picture i saved from ls1tech.com
kvn1011 is offline   Reply With Quote
Old 03-30-2012, 01:44 PM   #16
kvn1011
Kvn1011
kvn1011's Avatar
http://www.ls1fc.com/techinfo/pans.htm here is a link for comparison side by side of fbody and truck windage trays
