03-18-2012, 09:02 PM | #1 |
1978 k10 gets wound up at between 55 and 60
the motor gets way wound up on the freeway at 55 or 60, i beleive it has either 373 or 411 gears, is there anything i can do sans putting another rear end underneath it. motor has tons of power just gets wound up at 60
03-18-2012, 09:14 PM | #2 |
Re: 1978 k10 gets wound up at between 55 and 60
You can not put a new rear end in and instead just do a overdrive transmission. So pick your poison lol
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
03-18-2012, 09:15 PM | #3 |
overdrive, 4 speed manual (new process, not muncie) or higher rear end gears
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
03-19-2012, 11:39 AM | #4 |
any of the above, or drive slower.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-19-2012, 06:50 PM | #5 |
lift and larger tires
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
03-19-2012, 08:09 PM | #6 |
Thats the route I went. My truck is fairly happy on the highway now with 3.73s and 35s with the muncie 4 speed. When I got it it had 265/75r16s prob about a 31 or 32 and it screamed on the highway. Lost some power off the line but with the amount of highway driving I do with my truck it was worth it.
03-19-2012, 08:23 PM | #7 |
Good call, my 4.10 th400, stock tire combo cost me a head gasket doing 4000rpm too long on the highway. i was too cheap for a lift but made the 37" toyos fit, now it loves the highway lost over 1000RPM
80 k35 3+3 DD (big dirty) 85 k1500 DD (scottsdale) and then a few more |
