![]() Join Date: May 2002
Van Tilt Neutral Safety Switch Part Number?
Hey everyone, I recently purchased a tilt column from Dave who said this was from an early 80s motorhome. I've taken it apart, cleaned it up, and repainted it. I was trying to get the neutral safety switch to work properly, but when I set it for neutral it starts fine, but the reverse lights don't work. When I set it for the reverse lights to work, it won't start in park or neutral. I stopped at the parts store to see about replacing the neutral safety switch, but I don't know if I would be getting the correct switch. One place couldn't find anything, and another place gave me the part number of BWD S9210. It appears to be the same switch, but I'm curious to know if it will do the same thing. Is there a different neutral safety switch for a 700R4? For the people who have replaced the neutral safety switch on a van tilt column, what is the part number that you got for the switch? Thanks
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
#2 | |
Just a Member
Re: Van Tilt Neutral Safety Switch Part Number?
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
#3 | |
Always on the hunt...
![]() Join Date: Sep 2006
Hey Mike, per your pm and also out of curiosity, I just went and picked up a couple of the #S9210 switches and they both have that plastic locking pin in place that you mentioned on your switch. I am thinking it's a one time deal used maybe for setup or even shipping? Anyhow you can install the switch by moving the inner shift tube till it all lines up allowing the switch to drop in, then tighten the switch screws and now move the shift lever and it will shear that plastic pin allowing the inner switch tab to now slide back and fourth. You can also do this by hand with just your fingers using slight pressure. Mel
