Old 03-19-2012, 02:45 PM   #1
ctandc
Converting 6 lug axles to 5 lug
Thinking I'm going to change everything over to 5 lug when I do my disc brake upgrade. Local machine shop will redrill the axles.
What brake drums did people use who did this conversion?
Do the outside part of the axles need to be turned down to use the 5 lug drums?
Can you reuse the original 6 lug brakes shoes / backing plates and associated hardware?
Thanks.
____________________________
ctandc is offline   Reply With Quote
Old 03-19-2012, 03:36 PM   #2
Lower
Lower's Avatar
Re: Converting 6 lug axles to 5 lug
You can buy rear kits that include all you need for the swap for about the same price as the fronts and convert to disk too.
~Jon
Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=516056
Lower is offline   Reply With Quote
Old 03-19-2012, 09:15 PM   #3
ctandc
I’m cheap. The cost for me to swap in a later model steering box, later model tilt column, complete later model steering setup (new), control arms (with new bushings and balljoints) new rotors, rebuilt calipers, booster and master cylinder is cheaper than any of the disc brake “kits”.
In fact for the cost of the kit I can also add a front swaybar w/ new bushings, drop springs and new shocks.
I’m not looking for rear discs. I’m pricing out all different options now. Looks like my best find is to find a donor truck. I also plan on a 700R4 swap.
I’ll probably get the axles redrilled for 5 lug. Add in new bearings, new drums and it’s STILL cheaper than paying $190 (before shipping) for the 6 lug conversion drums.
