Old 03-19-2012, 03:11 PM   #1
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
K5 audio upgrade
I wanted to upgrade the audio system in my K5 but did not want to loose that stock look that the dash had, 1978 Vintage Sanyo 8 track AM/FM, in-dash Stereo provided.
Seen here providing tunes from yesteryear….
I did a lot of internet searches and this write up inspired me to do similar work.
http://67-72chevytrucks.com/vboard/s...d.php?t=229621
I like how he kept the original look and was able to use his audio knob to control volume from his Ipod to his sound system. I wanted to do the same but did not want to hack up a good working Stereo, and kind of dig the old school 8 track player!
Lead me to search for an amp volume controller and a Ipod to RCA wire on Amazon.
Here is what I ordered up.
I had a Coustic amp laying around that I used. I also ordered up a pair of 6.5” and 3.5” polks to put in the Blazer. Don’t worry I didn’t cut any holes that where not there when I got the truck, it had a pair of 6” Pioneer’s that matched the Sanyo for age!
I put the amp under the drivers seat to be out of the way and be closer to the driver for adjustments if needed.
Now I can enjoy Pandora, an Ipod/Ipad, an 8 Track or AM/FM
Speakers and cables are all that I ordered, I spent just under $120 for all of it. It sounds amazing, but is missing some much needed bass. I’m planning to add in a 6” bazooka tube behind the spare tire later on this summer. Don’t need to rattle my teeth so that should be plenty, and won’t take up much space either.
bowtieguy79 is offline   Reply With Quote
Old 03-19-2012, 04:30 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: K5 audio upgrade
Nice work! There's so many options now it's a waste to cut a shaft style dash to DIN. Nice to see one saved.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-19-2012, 05:48 PM   #3
1Bad65GMC
1Bad65GMC's Avatar
Thanks for this write up. I have been deciding the fate of my dash in both trucks and this is a great "cut free" alternative.
1998 GMC Suburban 2500 454 4X4
1984 GMC Jimmy - 3/4 ton axles, 5.7TBI
1990 GMC Suburban (Parts Donor) scrapped
1965 Buick Riviera - (Sold)
1999 Mercury Grand Marquis
1965 GMC SBSS (Sold)
1Bad65GMC is offline   Reply With Quote
Old 03-20-2012, 11:02 AM   #4
bowtieguy79
Ephesians 2:8
Thanks guys, really happy with how it turned out.
Old 05-04-2012, 09:44 PM   #5
My "custom" stereo is replacing the original mono AM/FM with an original AM/FM/Cassette stereo unit in excellent condition. Talk about stock appearance..it it stock! I have the speaker harness and stock speakers,but I saved the little Polk Audios from my '90 Blazer and will use those. I may run it through an aux amp. I have other stereo stuff I was going to use but decided to keep it simple.
OOPS! I meant to post this here:http://67-72chevytrucks.com/vboard/s...t=522930...but was on the link to this thread. I'm too lazy to change it...oh well.
Bowtieguy,you did a nice job with that!
Old 05-04-2012, 10:15 PM   #6
Jonboy
Slots go on anything!
Can you post the part numbers of what you bought on Amazon? I am wanting to do the exact same thing. I bought a cable at best buy, but what you came up with is way better.
edit- I found them. That wasn't as hard as I thought it would be. Thanks for the tip!
1974 Jimmy- 5.3/4L80e/NP241
Old 05-05-2012, 01:01 AM   #7
bowtieguy79
Ephesians 2:8
Glad you found them.
I added some bass! 200W powered 8"
bazooka, really sounds nice!
