Old 03-19-2012, 03:28 PM   #1
banno
banno's Avatar
Heater fan wiring issue
Hi Guys,
I need your help regarding some wiring issues for the heater fan. I can't find any wiring diagram for it. Please help me to piece the puzzle together.
Thanks in advance.
Best regards from Germany.
Martin
banno is offline   Reply With Quote
Old 03-19-2012, 10:04 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Heater fan wiring issue
ttt-anyone help out one of of international friends?
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-19-2012, 10:33 PM   #3
Larry64
Short orange wire at #4 on ballast resistor to #1 blower motor (thru grommit on firewall).
Large orange #4 on ballast resistor to #6 on switch.
#2 blue on ballast resistor to # 8 on switch.
#3 yellow on ballast resistor to # 7 on switch.
# 5 on switch is 12 volts DC to # 9 fuse block (connects at lug on fuse block marked heater).
Hope this helps Larry
Larry64 is offline   Reply With Quote
Old 03-20-2012, 10:08 AM   #4
ABX131
ABX131's Avatar
Someone was reading my mind...my truck also has all the wiring to the heater either cut or missing. This post is a major help. Thanks.
ABX131 is offline   Reply With Quote
Old 03-21-2012, 03:43 PM   #5
banno
banno's Avatar
Hi Larry,
thanks a lot for the fast response. The rewiring is done.
Unfortunately the fan motor is seized up.
I suppose that this was the reason why the preowner had cut all wires.
Martin
