Old 03-19-2012, 10:31 PM   #1
50bomb
50bomb's Avatar
67 chevy truck wiring
I have a 67 chevy c10 truck we are building. I want to use the original wiring on it maybe patch up what need to be. The truck read that it originally had a 292 with three on three Over drive. We dropped in a rebuilt later 70's sbc350 with th350 trans. Will I need to get an ORiginal 67 alternator to work for the regulater. I think the Alternator I have now is from a corvette and has the internal reglualter so I dont want to fry my original or replaced regulater. I rahter not cut up the original wiring to convert to internnal. Give me some ideas I suck at electrical. I prob make no sense either haha.
50bomb is offline   Reply With Quote
Old 03-20-2012, 06:05 AM   #2
gysgtc
Re: 67 chevy truck wiring
See if this link helps.
http://67-72chevytrucks.com/vboard/s...d.php?t=477136
gysgtc is offline   Reply With Quote
Old 03-20-2012, 10:53 AM   #3
50bomb
50bomb's Avatar
Actually that really does help if i keep the internal regulater. Thanks a ton. That will save me some bucks.
Old 03-20-2012, 11:27 AM   #4
68gmsee
Active Member
68gmsee's Avatar
On my 69 I converted to internal regulator and just left the regulator where it was. I did see years later where someone had a connector that you can just plug into the regulator connector. Maybe someone has the info on that.
68gmsee is offline   Reply With Quote
Old 03-20-2012, 11:43 AM   #5
68gmsee
Active Member
68gmsee's Avatar
If you don't want to cut and crimp, here's another post that I found.
http://67-72chevytrucks.com/vboard/s...d.php?t=500331
Old 03-20-2012, 11:54 AM   #6
50bomb
50bomb's Avatar
I am thinkin I just might just buy an exteranl alternator and replacement regulater if needed. RIght now I have a internal regulater froma corvette 63 amp. But nothing is wired up to it yet. Its sitting up on passesger side of block. This was originally a 292 truck so I might have to add to the wiring? Alot of GREAT IDEAS HERE. THANK A TON FELLAS! What to do what to do.
Old 03-20-2012, 07:05 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Save that internal alternator.. Mine was a 250 three speed manual and I went to a 350/350. There really wasn't much wiring to change except the alternator and the HEI which required a new wire from the back of the firewall to the distributor. I disconnected but left the original distributor wire in the cable harness. Lots of good info and howto in the electrical faq section.
Old 03-20-2012, 08:35 PM   #8
50bomb
50bomb's Avatar
I am leaning towards doing it this way now. Work with what I already have
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
