Old 03-20-2012, 01:52 AM   #1
Watts
20x10 All 4 Corners
I noticed a lot of people went with 20x8.5 up front with their boss or showwheel set up. I did the measuring and to me it looks like a 20x10 showwheel streeter will fit up front. What have you guys experienced with this set up.
I want to use 20x10 with 5.5bs and 0 offset on all 4 corners.
Watts is offline   Reply With Quote
Old 03-20-2012, 07:21 PM   #2
tubbedII
needs more $$$
tubbedII's Avatar
Re: 20x10 All 4 Corners
How low you go and your tire size matters in this situation. With about a 3/4 drop my bro's C10 had 15x10's all around with no issues, but I have no idea what the bs was on them.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 03-20-2012, 08:39 PM   #3
broey
Square
broey's Avatar
I run 22x10s on all 4. had to narrow the front 2 inches to tuck.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 03-21-2012, 10:56 PM   #4
Pro Performance
Pro Performance's Avatar
On a stock dropmember (not tucked in at all) the 20x10 will be tight up front and most likely rub depending on how low you go. I would suggest the 8.5" up front. If you did do a 10" wheel up front, I think it will take more than a 5.5" BS to clear the fender, etc.
Let me know if you have questions or want to further discuss your options. We are a Showwheels dealer, so I would be glad to help you out.
Pro Performance is offline   Reply With Quote
Old 03-22-2012, 09:55 PM   #5
jbice70gmc
jbice70gmc's Avatar
trenz68 has 20X10 on all four corners 6.5 BS front 5 BS rear. They look really nice.
1969 GMC SWB Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=486320
jbice70gmc is offline   Reply With Quote
Old 03-23-2012, 07:26 PM   #6
Pro Performance
It can be done, just have to make room for them!
Old 03-26-2012, 10:26 AM   #7
El Campo
El Campo's Avatar
I had 20x10 intros with 5 inch back spacing all the way around. The problem was that I had a 75 front end on it and it is 3 inches wider than my rearend. So it looked ridiculous. You need to have different back spacing in the front unless your front end is narrower than mine. Im sending mine back an getting 8.5 inch hoops put on
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
20x10
