Old 03-20-2012, 01:57 PM   #1
padresag
dana 44 frt and rear axle service bulletin
http://www2.dana.com/pdf/5310-3.pdf
how to service knuckle joints -whatever
ron
padresag is offline   Reply With Quote
Old 03-20-2012, 09:40 PM   #2
maxwoof
Re: dana 44 frt and rear axle service bulletin
That's awesome. Finally an answer to what you are supposed to lube the closed knuckle with.
maxwoof is offline   Reply With Quote
Old 03-20-2012, 11:07 PM   #3
pope
pope's Avatar
Thanks for the pdf manual Ron, it will make a nice addition to the library.
The operators manuals called for sae 90 oil to begin with, which is quite adequate though a 140 grade would leak out of the knuckle seals much slower. Either way you were to check them every 6000 miles.
pope is offline   Reply With Quote
Old 03-20-2012, 11:39 PM   #4
padresag
just google "Dana expert" or check the header on the pdf . there is everything there thaat you will need on dana axles
ron
Old 03-21-2012, 07:13 PM   #5
pope
pope's Avatar
Yeah, I saw that there but the site was having issues when I tried to open the link in the past. I frequently use their catalogs for heavy and med truck part number searches.
Where the hell did my coffee cup go?!!
Old 03-21-2012, 07:23 PM   #6
Woogeroo
Well, thanks a bunch padresag, you can be helpful when you want to be.
-W
Woogeroo is offline   Reply With Quote
Old 03-21-2012, 09:04 PM   #7
padresag
-W
always
ron
