Old 05-05-2003, 01:19 PM   #1
XXL
Seņor Member
XXL's Avatar
Question Hood struts in Pigeon Forge pic
Did anyone get a closer look at this hood strut setup? Is it just the stock hood hinges with a gas strut instead of springs? Where did the other end of the strut mount?
Thanks,
Kenneth
XXL is offline   Reply With Quote
Old 05-05-2003, 01:56 PM   #2
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Looks as if he removed the springs and added the prop rod on one end of the hinge and the other on the inside fender edge, clever engineering, I like the idea of no springs.
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 05-05-2003, 02:00 PM   #3
Low69CST
Wouldn't that take 2 people to open the hood? Or are my arms just that short? If he used shocks I would think they wouldn't last long as all, Thats one thing I hate about Camaros, shocks always go out
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 05-05-2003, 02:01 PM   #4
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I don't know, but I love that truck!! Man, the bags look sweet on that step!
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 05-05-2003, 02:08 PM   #5
lngbed71
lngbed71's Avatar
I can't tell but it looks like it is just a straight rod, no shock. I guess if it were a gas strut it would open easy.
Land of the free
Old 05-05-2003, 05:30 PM   #6
brad2
I saw that and assumed it was a strut. Sorry for the tiny pic but here is another example.
74 swb
71 2wd Jimmy
82 2wd Blazer
brad2 is offline   Reply With Quote
Old 05-05-2003, 07:41 PM   #7
XXL....If my memory serves me right, the lower side was just bolted to the outer fender. I could see behind it, but it looked like he had a hole with a bolt on the inner side (similar to the washer bottle bolts) .
Old 05-05-2003, 08:17 PM   #8
dinnut
dinnut's Avatar
do you have the pic of the red truck unedited?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 05-05-2003, 08:46 PM   #9
73stepside
73stepside's Avatar
the pic brad2 posted looks very similar to the thirdgen camaro/firebird hood hinge. the placement of the strut is in a different spot but operates the same. i don't think i wold do that. those stuts suck and they are a pain to change sometimes. if you have one that hangs up, then it ruins the both and have to be replaced. looks cool, but is a pain to deal with sometimes.
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 05-05-2003, 09:20 PM   #10
XXL
Seņor Member
XXL's Avatar
Thanks. Seems like a reasonable way to mount it. I may have to play around with that idea a bit. (As if I didn't already have too many projects going on at once .)
The original was in one of the Pigeon Forge pics threads. I just snagged it from there and did the mod to it.
Kenneth
Old 05-05-2003, 09:53 PM   #11
wnc mountain
More hobbies than money!
wnc mountain's Avatar
I took a pic of that truck. I blew up the strut on the oposite side and it looks like a shock. I did not save the pic I had blown up but here is the full size pic.
'70 cst10/swb 350, 3 on the tree, factory buckets.
'70 GMC lwb 350/350 ps,pb
'72 c-10 lwb 350/350 a/c, ps, pb
'72 Blazer project
wnc mountain is offline   Reply With Quote
