plumbing electriuc fuel pump
hi there
i have a question here, i got a holley electric fuel pump and i still have to buy the regulator, now the question is what do i do for my overflow, my carb is an edelbrock 1406 and it has no return line so i have no clue about what to do here, wont my carb overfuel ? i am running a fuel cell and it has a return fitting on it,, but i am stumped on what to do ,,, any help appreciated, thanks mike
DIGGER 1984 GMC Sierra 1500 LQ4 T56 12B Chopped 2 1/4, Dropped 6/7, Shaved, Yenko Stripes 2004.5 CCSB GMC 2500HD DMAX LLY, 6" Liftmaster, 6 Fox Resi 2.0 325/50/22" Kumho A/T on KMW's LBZ MP, 5"Ex, Bullydog GT 1996 ECSB GMC Sierra 1500 350/4L60E, FL Headers, 2450 Stall, 6" Pro Comp,3" BL, Shock Hoops, , TrXus STS 38's |
Do what I did and cap it. I'm running the Holley red pump with the 1406 carb and just capped the return line.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
I don't have a return line on my 75. There's just one line that runs from the tank to the pump, then one from the pump up to the carb.
Slammed,
Be careful about capping your return line. Some fuel regulators are "bypass" type which have to have a return from the regulator to the pump. My suggestion would be to buy a regulator of this type, and run the return from there right back into the tank. The closer you mount this to the tank the easier your job is! Brian |
bpmcgee thanks that EXACTLY what i was thinking there should be,, good call.
on the other hand with the regulator that doesnt have a return outfit it wont "overfuel" the engine without a return line?? thanks guys mike
driving is in my blood
A holley red pump is pre set to 7.5psi- great for a holley, a lil too much for the carter/edelbrock. Just get a normal $25 holley regulator and install in line. There is no need for a return line with either the pump or the regulator. I use the regulator in both my trucks. I use a red pump and holley 750DP in the 78, a carter 9psi and carter 600cfm in my 79.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
red or blue
ahh see i have the blue pump...
crap i guess, i ll be gettin a regulator then ,,, thanks guys! mike
