03-20-2012, 06:25 PM | #1 |
Badass
Junkyard electric fan swap?
Any of you guys do the swap?
Can you post pics of your setup and what make/model car it came out of.. Looking to do my truck real soon thanks. Posted via Mobile Device
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
03-20-2012, 08:05 PM | #2 |
Re: Junkyard electric fan swap?
my 01 had lt1 camaro fans should be about the same for the square body
03-20-2012, 08:26 PM | #3 |
go with the ford sable i think it is for fans. they flow the most cfm. it is what the diesel guys are useing if i remember right.
03-20-2012, 08:59 PM | #4 |
ford taurus/merc sable are the best to get. they are two speed and flow more CFM than itll ever need. I personally have one out of my friends camaro waiting to get put in only cuz it was free tho. Only thing keeping me form actually doing the install is me not thinking the stock alt in my 85 will handle it.. I suppose there is only one way to find out
If I was spending money I would go taurus and never look back. |
03-20-2012, 10:43 PM | #5 |
Badass
How about ease of mounting . My buddy have me a mid 80s camaro electric fan but I don't think I'm goin to use it. Looks hard to mount. And kinda small single fan. I've it the temp relay for it in a box waiting to us. Also almost all taurus and murks fans are already out of the cars at the junkyard. I want somthing with a shroud too not just a fan. To pull more air if any one got any pics it would help alot!
03-21-2012, 12:20 AM | #6 |
BAD BOW-Silverado XST
I currently have an LS1 dual fan setup.
I'm replacing them with a Mark VIII fan. I need more air for A/C. Engine cooling is not a problem. Here is similiar conversion. http://www.off-road.com/trucks-4x4/p...oject1580.html Mark VIII fan info: http://www.fordmuscle.com/archives/2...cfan/index.php |
03-21-2012, 11:51 AM | #7 |
At the body shop.
Grand cherokee 4.0 fan in mine fits in the stock shroud. Ill get a pic in a bit.
" That didnt make it any newer " " Dont antique the equipment " |
03-21-2012, 01:07 PM | #8 |
Cruzzzn' Vet
03-21-2012, 01:13 PM | #9 |
At the body shop.
Super easy two bolts one screw.
im in Tulare if youre in town one weekend i could show you. Posted via Mobile Device
03-21-2012, 01:21 PM | #10 |
what all goes into swapping over to an electric fan
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
03-21-2012, 03:54 PM | #11 |
Taurus fan is the way to go..If my truck gets to 200* my fan kicks on and cools it down to 180* in about 2 minutes. It's 2 speed and I only use the low side. It will suck a towel up against the grill and hold it there.
03-21-2012, 04:25 PM | #12 |
What year taurus?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
03-21-2012, 06:33 PM | #13 |
has to be a 3.8 taurus or ford. however me id run dual fans lt1 or ls1 would be a simple swap. i think dual 3.8 fans is overkill unless you have diesel.
03-21-2012, 08:49 PM | #14 |
definitely a taurus fan. My neighbor has a 68 Chevelle with a 400 small block that runs high tens in the 1/4. He has a taurus fan wired into a switch for the high/low and he said he only ever leaves it on low and he can cruise around town without it getting over 200
Semi professional heavy equipment operator Amateur mechanic |
