03-20-2012, 07:24 PM | #1 |
rear drum removal
Need help to remove the rear drum. Have to replace the bolt studs and check the brake shoes. My gmc is 3/4 ton with full floating rear with 13" shoes. One stud remains. See pic of brake drum.
03-20-2012, 07:46 PM | #2 |
Re: rear drum removal
You need to pull the axle out, adjust the shoes in and hope it slides off. If not ENCOURAGE it.
xrcr |
03-21-2012, 12:04 AM | #3 |
Yep, pull the axle, remove the snap ring and key, then unscrew the nut holding the hub in place. If the drum doesn't come off after that and some adjustment, get a large brass hammer or something that wont send metal chips flying into your face. Then talk to it sweetly while getting out any and all frustrations from the day.
03-21-2012, 02:05 AM | #4 |
They are right but make sure to wear safety glasses if you have to persuade it off.
03-21-2012, 11:34 PM | #5 |
Thanks to all for the help, i finally coaxed it off with some help. The bad news is i need all new parts, b drum pads,etc. Would it be feasible to change to a disc setup. Thanks frankyjoe
