VIN number
Ok I can not make sense of my trucks vin number it reads
1GBHC34T....the rest i cant make out. but according to what I have seen the first three numbers should be IGC for chevy or IGT for GMC. the 4th number H is the 9001-10,000 hydraulic brakes.-- mine has that the 5th is C for a 4x2 truck.-- mine is 4x2 the 6th is 3 for the series 1 ton or 30 series.-- Mine is a 1 ton. the 7th is 4 for a 2 door truck.--- mine is a 2 door the 8th ( my confusion problem ). the letter T or possibly J. T is for the 4.8 292 v6, J is for the 6.2 diesel v8. my truck has had the motor changed but on the interior visors it has diesel starting instructions. did they put the v6 in 1 ton dually long bed pick ups? also what about the first 3 letters the clearlt do not say IGC or IGT. heres a pic.
1980-84ish 1 ton chevy "Plow Boy" K30 dually 2wd all steel flat bed 350, holley carb, headders, weiand intake, 4spd granny, 14 bolt rear. 08' Scion xb stock..... for now. |
Re: VIN number
I'd take some fine sandpaper and lightly scuff the letters and numbers.
That should add contrast and make reading the vin easier... Check this out http://www.fullsizechevy.com/forum/g...-decoding.html Looks like the "B" denotes cab and chassis vehicles... Posted via Mobile Device
![]() ![]() Last edited by joe231; 03-21-2012 at 01:48 AM. |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: VIN number
I read "1GBHC34TG******"
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Re: VIN number
No -
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Re: VIN number
My thoughts exactly, it doesnt look to be tampered with...ahhh who knows bottom line i guess is i like the truck and i have fun driving it. Thats what matters right? ooh and its a 4spd also to mu knowledge the smallest engines those came with was the 305 v6 but that truck was to new to have a 305 v6. Is there a vin anywhere else to look at?
#6 | |
Re: VIN number
#7 | |
Re: VIN number
K
Re: VIN number
If the VIN is located on the dash your vin number is 1GBHC34T........
1=US made G=General motors B=Incomplete vehicle H=9000-10000 C=Conventional cab 4X2 3=1 ton 4=2 door cab T=292 This most likely was produce as a vehicle without a box given the "B" code in the vin number. The dealer probably added the box. Allot of 1 ton were built this way to allow for dealer options, box bed, flat bed, utility box ect. |
Re: VIN number
Do you have the title?
What VIN is on it, and what model does it show? Posted via Mobile Device
Re: VIN number
No I dont have it, a while back I had to take out a small title loan.
Re: VIN number
Just got the whole vin off the plate, and checked it... 1GBHC34T0DV103528
Country: USA Model year: 1983 Made by: General Motors - incomplete vehicle Drive: 2WD Series: 1 ton (30/35) Body: Pickup Plant: Pontiac Serial #: 103528 So could it have been ordered without an engine, and the dealer added the 6.2. Even the man i bought it from said it was a diesel from the factory ( a family member of his bought it new). So did the plant just throw some random vin on it? According to vin calculator it is incomplete with a valid check digit of 0 and nothing under the model and engine size feilds.
1980-84ish 1 ton chevy "Plow Boy" K30 dually 2wd all steel flat bed 350, holley carb, headders, weiand intake, 4spd granny, 14 bolt rear. 08' Scion xb stock..... for now. Last edited by 1965 Chuvy; 03-21-2012 at 02:18 PM. |
Re: VIN number
According to detectthis.com.....
#13 | |
Re: VIN number
No (that'd be a regulatory non-compliance). K
#14 |
Re: VIN number
Cool thanks Keith. So with all that clear I now know because of the dually set up and used to be long frame and the 292 with no color code and the "GB" for van chassis it was most likely a box truck.. My second thought would be a rollback. My dad actually had an 80s rollback, and wrecker with a 292. So Keith, If it was built with a 292, would the dealer give the option to have the 6.2 put in. And if they did would they install sun visors with the starting instructions. I am only asking because in 1983 the 292 was a very cheap option and in my eyes the dealer wouldn't mind making a few extra $$ to put the diesel in for a customer.
#15 | |
Re: VIN number
Here is the info packet from the GM Heritage Center archive, which will explain the available options on an 83 one ton pickup. http://www.gmheritagecenter.com/gm-h...olet-Truck.pdf One other option would be to send the VIN (and $50) to the Heritage Center and they can retrieve the vehicle invoice for your specific truck, complete with all the options it was built with (and corresponding pricing). Info is available at that same website. K
#16 |
Re: VIN number
Sorry - disregard - had another thought but it didn't pan out.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-21-2012 at 04:45 PM. |
#17 |
Re: VIN number
Its kool I like that PDF its very useful, and it reminded me my truck also has dual battery trays too.
#18 |
![]() Join Date: Oct 2011
Re: VIN number
292 was a L6, not a V6. (a.k.a. Straight 6)
L for longitudinal.... |
#19 | |
Re: VIN number
K
#20 |
Re: VIN number
Possible that somebody didnt just replace the visor with one from a boneyard???
#21 |
Re: VIN number
Oh I know I must have miss typed it. I have had plenty of the old 292's only thing I hated about them was the damn distributor, constantly effed up and made em run crappy. Being a mechanic and all im soused to writting out v6 because the only things you see L6's in anymore are volvos, canyons,and pre 2005? jeep GC's
1980-84ish 1 ton chevy "Plow Boy" K30 dually 2wd all steel flat bed 350, holley carb, headders, weiand intake, 4spd granny, 14 bolt rear. 08' Scion xb stock..... for now. Last edited by 1965 Chuvy; 03-21-2012 at 10:53 PM. |
