Old 03-21-2012, 01:08 AM   #1
usnabill
usnabill's Avatar
Cab floor
Is there a company that sells new center sections of the cab floor? It seems everyone sells the replacement foot wells, but I have yet to see a "high" or "low" hump for sale. A previous owner hacked up my low hump in an attempt to convert column to floor shift and I'm not sure my fabrication skills are up to the task... I will try to post pics of my cab floor tomorrow. On a side note, is POR15 recommended for use inside the vehicle or on the frame only? There is some significant pitting inside parts of the cab that have not rusted all the way through, but feels fairly solid still- seems that product may be useful there.
usnabill is offline   Reply With Quote
Old 03-21-2012, 01:14 AM   #2
losthope
losthope's Avatar
Re: Cab floor
Ive used Por-15 before it is a great product, i coated the whole inside of my classic car floor before i layed down soundedner to seal the floor, you can use it on many areas not just your frame it can be sprayed,rolled,brushed on....only advice is dont get it on anything you dont want it on!
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 03-21-2012, 07:25 AM   #3
6flee3
6flee3's Avatar
Re: Cab floor
What were they thinking? I've got the same problem, can get by with por15 on the rest of the cab floor but need the center section also.
Kinda scared to see whats underneath!
6flee3 is offline   Reply With Quote
