Interchangeable Pulleys?
I am planning on putting power steering and a/c on my '68. The pulley on the water pump and the drive pulley are both single belt pulleys. A, not-so-local, junkyard has a '69 with a straight 6 that has dual belt pulleys on the pump and drive. I have a 307 with factory nothing. Are the pulleys interchangeable? I took some pics of the junker and can add that, if necessary.
#2 | |
Re: Interchangeable Pulleys?
Do yourself a favor and keep an eye on the parts board. When you see somebody parting such a beast, buy both the crank and water pump pulleys and use them and only them. I haven't had one single issue with my belts since the day I put on that matched set from a short water pump truck that had air. BTW I didn't add the power steering to my rig but I did add factory AC. When it came time to charge the system, with the correct pulleys it was as easy as buying an AC fan belt for a 1971 truck with air.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
I am a Referee of life.
Matched pulleys,pump and brackes are the only way to go.I would ask what they want for the 6 Cyl stuff.Mght be a bit of profit in the resale.Get it all.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
After hunting pulleys for all mine,I agree-Get it all off the same engine at one time.Will save you a lot of headaches!
Doesn't have to be a 67/72 truck. Just about any Chevy with all the accessories you want will work as long as it uses the same water pump. Mike. ![]() |
Interesting thread.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
![]() Join Date: Apr 2007
The 6 cylinder stuff will definatly sell.
