Old 03-21-2012, 09:00 PM   #1
fatgump
fatgump's Avatar
Porterbuilt Crossmembers
Does anyone here have the Tubular Replacement Frame Crossmembers from Porterbuilt? Can a novice install them? I really like the look.
fatgump is offline   Reply With Quote
Old 03-21-2012, 09:46 PM   #2
Autoblueprint
Autoblueprint's Avatar
Exclamation Re: Porterbuilt Crossmembers
It is just a matter of punching out the factory rivets...however...with the engine / front clip and or bed installed...you might find you do not have ample hammer swing area to hit the punch hard enough to drive out the rivets.
If you have an air compressor with ample CFM to run a compact die grinder ( air file ) so you can grind off the rivet heads and an air hammer to punch the rivets out, then you should not have problems.
Most rent-all places will have these items.
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
Old 03-22-2012, 11:01 PM   #3
fatgump
fatgump's Avatar
Thank you for your response. The truck is currently at this stage. It seems Im either ordering the wrong parts or Im changing something thats already done. This is bad when you are on a tight budget and a beginner.
Old 03-23-2012, 12:01 AM   #4
firedog
firedog's Avatar
check out the suspension section you will find nate from porterbuilt answers a lot of questions there
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
