Old 03-22-2012, 12:45 AM   #1
RexDodge
I hate rivets II
I know many of you and been there and done that...but I just want to say (again) how much I hate rivets ! Now that I am almost done I have gotten good at taking them out. I tried the drill method and it didn't work for me. I have been cutting one side off (or grinding it off) and smacking them with a cold chisel to get them started. Then grab a drift and drive it home. Anyway...I still hate rivets.
RexDodge is offline   Reply With Quote
Old 03-22-2012, 01:22 AM   #2
SBC
SBC's Avatar
Re: I hate rivets II
You are not alone! Getting ready to install my porterbuilt pieces and been removing rivets when I have time for the last couple of days. I have one more left but baby starting crying so I had to leave the garage.
1967 C-10 Project
2008 Suburban
2017 GMC Sierra
SBC is offline   Reply With Quote
Old 03-22-2012, 08:30 PM   #3
LEEVON
Moderator
LEEVON's Avatar
Yep, hate em! I cut an "x" in the head then blast them off with the air chisel.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 03-22-2012, 09:24 PM   #4
Hubscrub
Cruzin
Hubscrub's Avatar
yea an air chisel is your best friend with these guys
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 03-22-2012, 09:38 PM   #5
Rob68c10
EXACTLY! I will never do a rivet any other way now that I have used this method. A million times better than any other way.
Rob68c10 is offline   Reply With Quote
Old 03-22-2012, 09:44 PM   #6
Ackattack
Ackattack's Avatar
That's my method too....still not fun, but beats the hell out of them trying to drill them out and beating them out by hand.
Ackattack is offline   Reply With Quote
Old 03-22-2012, 11:12 PM   #7
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Can you splain a bit more? Do you cut the "X" as a place to start or hold the chisel in place? How does this method get them out the other side?
Zoomin is offline   Reply With Quote
Old 03-22-2012, 11:39 PM   #8
six-T-seven
Cut across the face of the rivet making a pattern that looks like a Phillips head screw. Then hit from the side with your chisel. It not only cuts, but it bends the "quartered" piece in such a fashion that it breaks that section off. Move to the next "quarter" and repeat. You can chisel the large frame rivets off in less than a minute with a sharp chisel.
You still need to take a punch and whack 'em to get them out the other side.
six-T-seven is offline   Reply With Quote
Old 03-23-2012, 12:27 AM   #9
RexDodge
Great tip!
Old 03-23-2012, 04:47 PM   #10
LEEVON
Moderator
LEEVON's Avatar
The downside to the "x" method is that you have to be careful how far you cut the "x" in the head, or you will make marks on the substrate (frame, etc). And you need to cut them evenly in halves. If you cut one line too far to the side of the head, it can be a real bear to blast it off still. The "x" relieves enough material to allow the 4 pieces to bend and break off when you get the chisel under them, instead of directly shearing, pushing or beating the metal s you would be doing with chisel only.
Too many words, if I had a pic that would do!
