03-22-2012, 01:43 AM | #1 |
In the Forgotten far North.
Really cold drive to work this morning.
The temp this morning was 2*F so I started the truck up with my trusty remote start to let the burb warm up before leaving for work. Go out about 15 min later and leave for work (maybe 8 mile drive if that)
2 miles from home, my heater's putting out cold air.... Hmmm... I look at the temp gauge and it's reading 240* Middle of traffic and I have 14 stop lights to go through before I reach work (GM Dealership) Usually I can catch these lights all green or just turning yellow when I hit the intersection so I figure ok it's real cold out, and I'm travelling along at a fairly good pace so let's hope I can make the lights.... WRONG!!!! EVERY SINGLE LIGHT IS RED!!! Now the longer I'm driving/sitting at a light the higher my engine temp is getting...245*...250*...255*... Finally get to work and get the burb checked into the service dept. punch in and get to work at the back parts counter. Couple hous later the tech comes up and informs me that the heater pipes goig back to the rear auxillary heater have rusted thru and my rad cap was weak. Down to 11psi from the indicated 16psi. So I looked up the heater lines and YUP THEY ARE DISCONTINUED WITH NO STOCKING DEALERS ANYWHERE!!! So for now I had them install a reducer/coupler in the hoses under the hood that lead back to the rear heater (3/4" hose to 5/8" hose) to bypass the rear heater, refilled the radiator and replaced the cap. They then did a pressure test on the system and thankfully it held pressure just fine with no indications of coolant leaks into the oil or cylinders. All I can say is the ONLY thing that saved my burb from a catastrophic event was the REALLY LOW outside temp helped keep the engine just cool enough to reach work. So now I gotta find something to make the hard lines out of to run back to the rear heater. Sounds like a summer project to me. Maybe if I can find some 5/8 and 3/4" o.d. copper pipe. We'll see.....
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade Last edited by BLE 'BURBAN; 03-22-2012 at 01:54 AM. |
03-22-2012, 03:36 AM | #2 |
Re: Really cold drive to work this morning.
If you wanna go this way..... and not sure how much shipping would be on top of the already high price, but LMC carries the lines now.
1995 Suburban K2500 454.....off road & towing 1999 Astro, work van 2006 Silverado 2wd 5.3 w/4.5" lift and 33s |
03-22-2012, 06:15 AM | #3 |
I've repaired those before by running rubber lines all the way back.
Something to consider, rather than re-creating the hard lines. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-22-2012, 10:23 AM | #4 |
Yeah for $400.00 + another 125.00 for shipping. No thanx!
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
03-22-2012, 10:31 AM | #5 |
Thought about that as well... And I do have a enough 5/8" silicone heater hose here. Would only have to get some 3/4" hose and something to use for shielding to keep it from chaffing & protect them from road debris. Perhaps large diameter split wire loom? Hmmmmm something to consider.....
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade Last edited by BLE 'BURBAN; 03-22-2012 at 10:38 AM. |
03-22-2012, 03:05 PM | #6 | |
Now, I can't say for sure that they were the originals....they were definitely quite old, but didn't leak a drop. Being that I live in Las Vegas, I removed the lines completely.
03-22-2012, 03:45 PM | #7 |
78K & 79C Jimmys
mine was done the same way,by same company
some places make custom lines....had to get some done for a lowered van a while back
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-22-2012, 09:08 PM | #8 |
Well with 129" of snowfall so far this winter and no garage, I'm gonna wait until end of May-early June to get this puppy back up and running right.
03-23-2012, 12:10 AM | #9 |
I helped a friend with his. We used Copper tube, as he had access to a "stockpile" of it. He ran an HVAC company. It worked great.
1998 GMC Suburban 2500 454 4X4 1984 GMC Jimmy - 3/4 ton axles, 5.7TBI 1990 GMC Suburban (Parts Donor) scrapped 1965 Buick Riviera - (Sold) 1999 Mercury Grand Marquis 1965 GMC SBSS (Sold) |
03-26-2012, 11:33 PM | #10 |
Chevys Kick A$$
Damn that sucks what a long rough ride to work. I would have been stressing and speeding haha! That sucks big time glad to hear that the motor didn't overheat though
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
04-02-2012, 09:53 PM | #11 |
i have rear air, but i'm pretty sure mine doesn't have rear heat. was that an option? was there just a heat exchanger in that rear air unit?
04-02-2012, 10:38 PM | #12 | |
78K & 79C Jimmys
Yes there were units with both up top(my88 from Texas) But mostly heat was on the floor here Posted via Mobile Device
04-02-2012, 10:42 PM | #13 |
i gotcha. i've got rear air only. i'll bet these burbans get awful cold in the winter, and rear heat sure does seem like a good idea! i'm still working on mine, haven't got to drive it yet!
04-02-2012, 10:59 PM | #14 | |
78K & 79C Jimmys
Lol could be a burrr bin,aka cold box Posted via Mobile Device
04-03-2012, 12:37 AM | #15 | |
She's parked for the duration now until I can get a few minor things for it like.. 1. Cat Convertor 2. Steering linkage 3. Shocks & ball joints. 4. Rear brakes 5. Tires
04-03-2012, 07:00 AM | #16 |
78K & 79C Jimmys
lol we should start a weather thread ,or is there one?
wind,snow, rain....and our trucks gettin through we could even track storms....
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 04-03-2012 at 07:07 AM. |
