Brake booster / master cylinder help
I'm prepairing to shave the fire wall and since I will have the front clip off, it seems like a good time to add some paint. As one job snowballs into another I figured time to say good bye to the original Brake booster / master cylinder and hard lines from 1972. ordered the set up from Classic Industries based on what was listed on their on line catalog. Got the correct bendix booster but received a master that is part # MC39075. in an older catalog this is lister as being for a 71-75 3/4 ton and 71-73 1 ton. also states moraine cylinder??? Anyone else run into this? also I beleive this is a 1 1/4 bore, cpp list correct length to be 1 5/8 deep push rod hole (part # M-87002 so what to do? thinking return the CI and get the cpp. Any info would be greatly appreciated. Thanks
